SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
SOURCE: Harmony 890 Pro dropped.....everything looks fine but it no longer controls system
You will have to open the unit up and repair whatever broke.
When this has happened in the past to less complex remotes, I have found that usually the oscillator chip has broken off of the circuit board, but whatever it is will have to be resoldered back into its original position.
If you have never worked on electronics before, you will have to take it to a repair shop, send it to the manufacturer, have a knowledgeable friend repair it or buy a new one.
SOURCE: Harmony 880 Remote Control appears frozen
Hi!
You need to reset the remote control. Pull the battery out of the unit. To do this slide down the back cover off. Reinstall the battery after 2 minutes and it will reset the remote and you will be able to again use it.
Thanks for using FixYa and do rate the solution as fixya if found helpful.
Thanks
Rylee
SOURCE: Harmony 900 to control Bose Lifestyle problem.
Press the system button on the Lifestyle remote control. Move right to see a preview of the remote control. Press the down button to move into the submenus. Go down to IR Control. Select "on" System receives IR commands from another remote that has been taught to operate this system. Press exit and take a breath and try your Harmony remote. It should work. I had the same problem and this fixed it after hours of screwing around. Good Luck
SOURCE: logitech harmony 890 display is blank
this sounds like it is a hardware issue, try contacting Logitech through e-mail from the website www.logitech.com and sending an e-mail in.
try the following before contacting them:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
If this doesnt work, provide them with the following to make sure the process goes as smooth as possible:
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
