Question about Whirlpool GD5SHAX Side by Side Refrigerator
Frigedair refrigator After moving side by side unit from one home to another the ice maker stopped working. Also freezer light wont come on. Everything worked for the first l4 hours, then all went dead. Freezer still is freezing , but no ice and no light
  • M A P Dec 31, 2007
    I have a similar issue but after moving the fridge the control panel settings stopped illuminating, and the light stopped working. If i remove the light then the control panel begins to illuminate again. If i insert the light it appears to have a weak electric supply and the control panel stops working.
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Posted on Jun 03, 2008
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Temperature to warm
that is an automatic defrost problem
timer,heater or limit switch
Apr 22, 2009 | GE Profile PCF25PGW Side by Side...
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Nov 13, 2007 | Refrigerators
Whirlpool GD5SHAX Side by Side Refrigerator Logo
227 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
