Question about HP Photosmart C6280 Printer
It won;t photocopy now and prints blank sheets from open office documents
  • 2 more comments
  • smo2 Jun 30, 2009
    I don't have the drivers and don't know where to get them.
  • smo2 Jun 30, 2009
    I have dwnloaded the drivers from HP the priblem still persists.
    Shirley
  • smo2 Jun 30, 2009
    I have checked and changed ink levels before without effect.I only have Open Office and find I can print things from online pictures but not Open Office documents. When I scan for photocopies I just get marks on the paper or just blanks it seems to be trying.If I scan to a file and print from that file it works.I wonder whether this is a hardware problem.
  • smo2 Jul 09, 2009
    I have found that it will copy on the colour button, although the black cartridge is full.
I'd like to assist. Firstly, please check the ink levels:
  1. Press Setup button on the printer itself.
  2. Press the down arrow button to highlight Tools , and then press OK .
  3. Press the down arrow button to highlight Display Ink Gauge , and then press OK . The HP All-in-One displays a gauge that shows the estimated ink levels of all cartridges installed.
If none of the cartridges are empty, you should try to reset and recharge them. Simply lift open the printer lid while the printer is turned on, and the cartridges will move into place. Remove each cartridge and ensure there is no label attached to the cartridge. New cartridges usually come with a label attached to the cartridge which must be pealed off before insertion.
Then place each cartridge back into their appropriate slots ensuring they snap into place, then close the lid of the printer. They will recharge automatically. Try printing again.
Are you now able to print? If not, can you print from another application besides OpenOffice.org?
You also mentioned the copier function doesn't work. Does it attempt to make the copy (can you hear the scanner scanning the page or similar sounds), but it just comes out with a blank page? Is this correct?
Let me know if the above has helped. If not, please let me know which operating system you are running (like XP or Vista).
Thanks.
Posted on Jun 30, 2009
    Genius:
  • 2,785 Answers
Plz try by reloading the drivers and check the by printing a test page. if every thing is ok then try to scan and print. plz post back if the problem is not solved
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
When I print from Word with my hp1600 I'm getting blank pages at the beginning of the print..If My document is 5 Pages I get 5 blanks before actual printing begins. If my document is 1 Page I get 1 blank...
try using a different word program such as open office* or even notepad, if it prints correctly then try reinstalling microsoft word as there maybe some accidental alterations in the printing setup on word.
alternatively try reinstalling your printer.
*open office is a free to use program*
hope this helps
kev
Dec 01, 2008 | Office Equipment & Supplies
Hp 920c
is printer driver installes if so go into control panel and check that the 920c is selected as active printer...
Sep 25, 2008 | HP DeskJet 920c InkJet Printer
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark X 83 will photocopy but not print
Ok thanks for the info:
Do you still have the the Installation disk for your printer?
Apr 04, 2008 | Lexmark X83 All-In-One InkJet Printer
HP Photosmart C6280 Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
