Question about Andis Outliner II Hair Trimmer
What is andis outliner II correct blade alignment?
  • 62 Answers
Please go to youtube andis to watch instructional videos. If you are still unable to align your blades please call our customer service dept at 1-800-558-9441 for assistance.
Posted on Aug 18, 2014
SOURCE:
  • 3 Answers
SOURCE: Andis Outiliner II Trimmers
Purchae the "How to adjust your trimmers and clipper blades" at www.alexccampbell.com
Posted on Apr 10, 2008
SOURCE: Andis T-Outliner
adjust the brown plastic on the blade all the way up.remov the blade and the brow plastic is held with screws
Posted on Apr 27, 2008
SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
  • 8 Answers
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Posted on Aug 01, 2009
SOURCE: My andis t-outliner keeps pulling hair when
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Posted on Jun 20, 2010
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
Step by step guide to cleaning blade!! Forgot which peice to put in first!
is this blade andis, oster,wahl detachable blade need to know what type of blade you have to help you
Jul 13, 2009 | Andis Outliner II Hair Trimmer
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Jun 15, 2009 | Andis Outliner II Hair Trimmer
How di adjust blades to make andis clippers sharper
Take blades off clipper,loosen screws on blade, place on mirror, rest teeth against mirror, angle clipper at 1 oclock position, slowly titen screws
Andis outliner
Andis factory for repairs at 1800 Renaissance Blvd Sturtevant WI 53177
Aug 23, 2008 | Andis Outliner II Hair Trimmer
Please return your unit to the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177 for repairs. If the unit is less than one year old please also return a copy of your receipt with the unit and all repairs will be done at no charge. If the unit is older than one year there is a $6.50 service fee and $5.00 shipping. There may be additional charges for parts depending on what needs to be done. If you would like to speak to an Andis customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Dec 21, 2007 | Andis Outliner II Hair Trimmer
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Dec 06, 2007 | Andis Outliner II Hair Trimmer
Andis Outliner II Hair Trimmer Logo
184 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
