Question about Garden
Hello i have a karcher b402 i have had it for a few years it is stating to leak water from underneath allthough not a problem what can i do with this please edwin read
  • 32 Answers
Hi, it sounds like the seals in the pump have gone,
you can repair this your self with some seals, www.karcher.com then click on europe,then international the screen will change.
go to services the spare parts, in put your model.
it will help if you can also find the 8 digit number starting with a 1.something something something dash something something something dot nort.
or ring me on 01729825656
Posted on Jul 04, 2009
Why is smoke coming from karcher pressure washer and leaking from underneath
You need to make sure you have water flowing through the machine before you turn it on. The pump could be bad in it and or the seal make have broken which is causing the Ayer o leak out.
Feb 04, 2015 | Karcher Garden
Karcher K2.26M water leak
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Jul 03, 2010 | Karcher K2.26 Electric Power Washer
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Water is leaking from under the chrome piece inside my Karcher 3.68m pressure washer. Hose intake and outlet look good. Any sugeestions.
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center, or if you are mechanically handy. Replacement Manifold Complete, is available from www.karcher.com.
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
Jun 08, 2010 | Karcher K3.68MR Factory Refurbished 1,800...
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher 360M pressure washer pulsating problem when idleing
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head or the plastic valve block on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this. Hope this helps Kind Regards Brad
Dec 16, 2009 | Karcher PSI Electric Pressure Washer
Karcher B402 pressure washer Motor runs as soon as power supply connected, on/off switch does not seem to make a difference and no pressure at outlet? Was working fine, stopped for half an hour, came back...
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Jun 22, 2009 | Garden
Garden Logo
509 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
