Question about York Yankees Bedding MLB Comforter
Just bought a cardiofit 220p but has no instructions for use. Can you help please.
Owners manual for schwinn 220P recumbent bike
This link will take you to the owner's/service manual for the 220P
http://www.sportsmith.net/images/product_support%5Cschwinn%5Cservice_manuals%5C220%20electronic%20trouble%20shooting.pdf
Mar 29, 2015 | Schwinn Cycling
Dymo 220P has a new cartridge but won't print
I should check that your new cartridge is identical to the old one. I have had a similar problem with blue plastic case cartridges, when my Dymo works perfectly with the clear ones. I have found that the blue ones do not have the gaps / notches at the bottom, but just the one! So I have cut off another slot, using the clear plastic cartridge as a template, added a bit of Dymo sticky tape because the new gap was too deep, and that was sorted! Good luck and mind your fingers! It looks to me like planned obsolescence!
Nov 14, 2012 | Dymo Labelmanager 220P Printer
I have toshiba satellate A11 220p/5 then I cant find driver any wher. pls help me
Hi Pup24
try on this page
http://uk.computers.toshiba-europe.com/innovation/generic/SUPPORT_PORTAL/
Maybe you`ll find the answer there .They will show you how to find the serial number for your laptop and then you will be able to locate the right drivers .
Hope this will help you ! Good luck !
Aug 26, 2011 | Computers & Internet
I have a Cannon ScanFront 220P. The page feeder will only work if I manually push one page in at a time. Is ther a way to fix this?
You should clean your pick-up and separation roller using cloth soaked in water. Be sure not to use alcohol because it reacts with the rubber roller.
Aug 12, 2011 | Canon ScanFront 220P Flatbed Scanner
Is it possible to get hold of a manual for a York Cardiofit 210p Fitness Platinum Series #8570, Exercise bike. Thanks
York Fitness manuals are available at:
http://www.yorkfitness.com/store/IIT_Instructions.asp
The 210p is a discontinued model, replaced by the 220p. Not much changed between the 210p and the 220p. The manual for the 220p would likely suffice.
Hope this helps.
Apr 27, 2011 | Cycling
Adjust date and time on Canon ScanFront 220P?
See this link to download the user guide. The information you need is on page 4-25 of the guide, where you need to set the region in which the scanner will be used.
http://downloads.canon.com/cpr/software/scanners/SF220IG.pdf
Mar 18, 2010 | Canon ScanFront 220P Flatbed Scanner
Where can I download a copy of a Schwinn 220P operators manual?
After some research, I have not been able to find a manual that can be downloaded. This is probably due to the fact that it is relatively large in size. Some manufacturers simply dop not digitize their larger manuals. You may be able to find someone who has done the work for you - but that may take some time. If you wish to buy it, here is one place: http://www.fitnessrepairparts.com/cart/ViewItem/13000747
As you may already know (which is probably why you are here), Schwinn does not have it in their download section for stationary bikes, which is here:
http://www.schwinnfitness.com/schwinn-fitness/customerservice/manuals.jsp?lid=Owners+Manuals+-+Manuals
but you may wish to try model numbers close to the 220p and the information may basically be the same.
Please be advised, this is free-of-charge information and opinion I am providing you. Please do not give me a low rating for simply trying to help. I may not have given you an answer you like, but it is an honest one, and one based on research. Thank you.
Jul 05, 2009 | Schwinn Cycling
New Scanner
Hi, I can only see part of your question and do not know how old the post is so you may already have the answer. In response to the first question, yes you can name the file/image at the time of scanning before sending to Email/Shared Folder etc...
Dec 30, 2008 | Canon ScanFront 220P Flatbed Scanner
York Yankees Bedding MLB Comforter Logo
107 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
