Question about Haier Refrigerators
I just bought it, plugged it in, worked for 3-4 hours and shut down. It's been doing that ever since for about a wk or so now. What could possible cause this? Thank you. Mary Ellen Pap
  • melpap Jun 29, 2009
    I would like to know if there are any other options. I can hear it kick on an off. Is there anyway, it would be related to the outlets in my home. I'm sure they are all standard 110v. I can't associate anything with why it will go on and off.
    If the answer is the one RE: transporting. It will never work right - please explain what it would be doing. Just going on and off as I described???
    Thanks,
    The refrigerator was put in my car by someone from the store and yes it was at a 45 degree angle in my passenger seat, but we spray painted it from it's basic white so it was not plugged in for well over 24 hours.
    President:
  • 828 Answers
See at the Manuals, maybe it set on Off Timer every 3-4 hours.
Posted on Jun 30, 2009
  • 439 Answers
Hello, when you purchased the fridge, did you transport it? Or was it delivered to your house. The reason I am asking is specifically to find out how it was transported. If you tilt a fridge 45 degrees or more, you are supposed to let it sit for 12-24 hours before use as the oil and freon in the system will get into the condenser lines and cause the compressor to prematurely malfunction. If you plugged it right in after transport then I would believe that is the cause. If it is store bought, I would ask for an exchange as your unit will never work properly.
Posted on Jun 29, 2009
My laptop shut down every one hours Exactly
Remove the battery and use the laptop with the adaptor plugged in to check if it still shuts down after one hour. Do a similar test with the fully charged battery installed and the adaptor NOT plugged in. If no problem with both tests there may be a problem with the charging circuit or possibly the battery.
Feb 28, 2014 | Acer Aspire 5516-5063 Notebook
Samsung dlp tv shutting down
Short of having a shop look at it make sure all 3 (this one should have 3) fans are not covered in dust or dirty---
other possible issues are the lamp and or the Ballast that drives it.
May 24, 2012 | Televison & Video
I have a RFG297ACRS (Canadian Model of AARS). Bought new and delivered yesterday. Waited 2 hours before plugging it in as directed by the delivery guys. Plugged in 24+ hours ago but until now it's still...
must be on demonstation mode, manual says the following: press ENERGY SAVER BUTTON AND FREEZER/HOLD 3 SEC FOR POWER FREEZER BUTTON simultaneously for 3 seconds until an alarm sound is heard.
Jan 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
06 Mazda 6, v6 won't start, jmper cables didnt wk, lights do wk
Pretty much got to be starter related. Loose connection at starter. Bad solenoid. Brushes in starter.
Rap the starter with a hammer and see if the engine will turn over after that.
If it does, you've found your problem.
Jan 02, 2018 | 2006 Mazda 3
Fridge water-dispenser not working, after shutting down water line from basement, due to plumbing repairs elsewhere. It was working fine the morning of, and after shutting down the water for about 2-3...
Water in unit has possibly iced up. Turn water supply off again and read you user manual on haw to defrost/deice unit. Furthermore ensure water supple is actally pressurised. Backflush the supply if possible.
Mar 24, 2010 | Refrigerators
My 5250 watt Power Back generator will not start, and their is no spark at the spark plug.
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
Jan 22, 2010 | Groove Tubes Power Back 5,250-Watt...
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 | Casio Music
Program
On Simon panels, the master code should default to 1234 if it's been powered down for several hours (I can't remember how long, at least four hours, possibly 12-16). So, unplug it from the wall and disconnect the system battery and leave it for the night. Power it up by plugging in the battery first and plug it into the wall. Then enter the code as 1234. It should annouce that the alarm system is disarmed. If so, your code is 1234. ;)
When removing the battery, be very careful to not break the little tab that holds it shut! Can't stress that enough.
Oct 19, 2008 | GE Security Simon 3 Wireless Home Security...
Blue-ish tint suddenly ?
the solution is as its follows: :)enter in
Factory Menu
1. How to enter factory menu:
2. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
paul@ula.ve -> had to use the already written text...:P
3. with the keypad look for the menu that says <more options> on the bottom of the osd. once you are there go for the option HARD RESET.
4: also look for the option where its says SOFT RESET. its on other tab ... shut down the projector. take the power cord off the 6100. wait for about 10 seconds. plug it again and there you go...it works again.!!
francisco.arana@gmail.com
Oct 11, 2008 | BenQ PB6100 Multimedia Projector
AC shutting down, not cooling
your landlord needs a service tech !sounds like you have a few issues.possibilities include control issue,plugged evap coil,plugged blower wheel,possible freon issue.This one's a little too big to handle here.
Jul 26, 2008 | Ruud UBHC Air Conditioner
Refrigerators Logo
66 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
