Question about Nokia 6225
Settings received but not saved. message deleted
Hi All, I've a Nokia n73 and few dayz bak i've formatted phone memory as well as memory card. After that i re-activated my gprs connection (i've BSNL connetion ) and i got the message "GPRS has been activated successfully now u can download the settings" so when i tried to download the settings i sent nokia n73 to 58355 after some time i received some 4 msgs stating that "settings received but not saved. message deleted " i tried many times , called bsnl care they told itz not their prob . So can anyone help me to sort out this prob?
Any effort to fix my prob would be highly Appreciated.......
  • 493 Answers
1. The phone may not have enough memory to save the message. This may be one of the problems. You say that you have just formatted the phone and card memory. The memory card may not be formatted well. Be sure that the memory card in the phone is accessible and can be read.
And you say that you formatted the a few days ago. Maybe it is full. Please check it. Because your downloaded messages may need extra space.Check the message settings where to save.
2. The other problem may be the multimedia message settings.
- Select Messages > Options > Settings > Multimedia message.
- Check the settings for multimedia messaging. It must be defined correctly and be sure that there is no mistake in phone numbers and addresses.
3. If you installed any application and even if you installed that application to PC or memory card, the installation files (.sis) of applications that are stored in the phone memory remain in the memory. Remove such installation files from the device memory.
After backing up the installation files if there is any, delete the installation files using file manager.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Posted on Apr 12, 2010
Please help me I already try what you said mr.ioktay but it doesnt work. my phone is nokia e71 i have 3 gb space. on my memory.
Posted on Jun 26, 2010
Dear you change your Sim card & go http://www.bsnl.co.in/service/mobile_gprswap.htm(problem in your Sim card)
Posted on Dec 20, 2009
My Nokia N73 keeps on giving an error "Memory full and delete some data " where as phone memory very much free and doesnt have much of application.Please help..
This problem arises when your phone settings are so as to save everything on the phone and not on the memory card. For that you have to select your camera go to settings and select memory card. Same way you can save you messages into your memory card this will help you because when you share something with blue tooth it is saved in you in box.
Go to messages press the options button select setting.
then go to other and in memory select memory card. It will ask if you want to move your existing messages from your phone to memory card, select yes if you want and save the settings.
Oct 17, 2010 | Nokia N73 Cellular Phone
Hi.. My nokia N73 is always showing as phone memory full delete some data.. i have done resetting the phone multiple time still it is showing same problem ..
try ( * + '3' + 'call button') hold this three keys and power up ur mobile without simcard dont leave the button untill u get the countries name for further details.be sure to save or backup data saved in your phone and memory card. this format will remove each and every file saved in your phone memory or memory card which cannot be restored if deleted once..
May 20, 2010 | Nokia N73 Cellular Phone
HOW TO REFORMAT PHONE MEMORY OF NOKIA N73
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
Hope I make it clear and does makes sense.
Thanks..
Mar 31, 2010 | Nokia N73 Cellular Phone
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
Messages are not deleting from my phone memory card
Hi .. this is a virus impact .. you cant escape formatting the memory card.. or else just scan the virus and plug it off the affected...
May 29, 2009 | Nokia N73 Cellular Phone
Screen keep appear 'memory low. delete some data'
just change your prefered storage to memory card...actually your selected memory is phone memory...so thats why every file received from bluetooth save in phone memory..to change your stroage go to messages ------> settings-------> change your storage from phone to memory card....i can send you a detailed procedure if you want
Oct 10, 2008 | Nokia N73 Cellular Phone
Saving Bluetooth Messages in Memory Card in Nokia N73
go to message settings-- other settings---change memory in use to memory card by options... welcome-----. sai..saidheerajmv@gmail.com
Jun 02, 2008 | Nokia N73 Cellular Phone
Memory full
Happened to my n73 twice. Format the phone to get rid of junk piled inside the phone memory.
To format:
  1. turn phone off.
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
Your phone will gain 44mb back and go back to normal. Phone will respond a lot faster too, as if it were new. Viruses would be deleted as well as other junk stuffed inside.
Important reminder:
If you have anything stored on the phone memory that you woudn't want to delete, such as pictures, videos, or whatever, back it up to your memory card or computer. The format process deletes all stored memory on the phone, but not the memory card.
Dec 23, 2007 | Nokia N73 Cellular Phone
N73 me
try this...it worked!!!!!!!!!!!!!!!!!!!!
take a backup of all u need n memory card...
remove memory card from the cell
go to lifeblog application then mark all and delete them...
then put back memory card and check it!!!!!!!!!!!!!!1
the lifeblog application eats up memory
Dec 19, 2007 | Nokia N73 Cellular Phone
Memory full?
try this. this helps me..
turn off your n73 phone. turn it on. while your mobile is booting, hold
3 + * and the green call key at your left soft key until it ask your location.. select your location and BAM! your phone is new again and 44mb is back.
note: before doing this back up your files to your memory card and remove it removed it from your phone. =) This is SAFE!
Nov 19, 2007 | Nokia N73 Cellular Phone
Nokia 6225 Logo
1,366 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
