Question about Sunon (16-02-006) Fan Kit
Dc fan with this part number12-87366-02
Dc fan with this part number 12-87366-02
    Scholar:
  • 161 Answers
Fans are interchangeable parts in computers.
alright bust out your ruler and measure the diameter across.
typical sizes are 60mm, 80mm and 120mm
you can buy all of them and awesome light up ones here
http://www.frozencpu.com/cat/l1/g36/Fans.html?id=iW3bmbvy
Posted on Apr 06, 2010
Does not goes to the recommanded temp.
If you have a 12 dc power source like a battery charger you should be able to direct test the motor. It should run for you on that voltage--watch polarity. Usually the problem is the mother board (main board) but fan motors go bad also. Main board number is WR55X10942 at about $!50 retail.
May 07, 2015 | GE Profile PDS22SBSRSS
Fan wont come on
Make sure that the fan is 12 DC Volts.. If that is 12 DC volts?... you can connect that fan to power supply of your desktop wired color (+)yellow and ( -)black. If its doesnt work... that fan is defective.
Aug 16, 2014 | Computers & Internet
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
My Panasonic is Model# SA-ht650. The fan does not come on to cool the unit down. I took the fan out and tested it and it does work with 12 Volts DC @ 1.5 amps. Any suggestions.
For others, the fan on this model only runs with the volume turned way up, to test it unhook the speakers and play something like the radio with the volume set to 0dB, the fan should run.
Dec 23, 2010 | Panasonic SC-HT650 System
Where can i get a dc fan motor for model number 2312dc hamilton beach water dispnser fan motor number d90 sh-12
Call any appliance parts store in your area, you'll need the make and model of the unit and since you already have the part #, you should not have any trouble. I believe Sears Appliance Parts store carries this brand.
Good Luck!!
Sep 26, 2010 | Hamilton Beach Water Cooler with Storage...
Fan on my big buddy heater just stopped working changed batteries still not working?tried the switch nothing .i only have radiant heat.
I would first check the wiring connections to fan and get a multi meter , set on 12 volts dc and see if fan motor has 12 vdc input voltage.
Too cheap to buy a voltage tester at wal mart ot harbor frieght, you can use a 12 volt bulb and socket, if you already have one. Remove fan wires & hook up 12 volt light bulb & if it lights, you got the juice. Carefull,dont let live wires touch because you short out $26.00 big buddy fan transformer. work with fan transformer unplugged from wall and dont plug in until you sure no wires touch.
use electrical or duct tape. electrical tape better.
otherwise,just buy the multi meter, they only $8.00 to $10.00
read & understand instructions, before you try to use it. otherwise,you could burn out your new meter.
well worth owning &
learning to use multi meter. I use it thousands of times.
if fan motor has juice but wont run, check fan shaft to see if it turns freely or scrapes or is stuck. oil fan motor bearings ,change the brushes.
make sure that the fan blades are not touching the fan housing and can turn freely.
if it still dont work, buy new fan motor.
if no juice at fan motor, check mr heater switch with the power off,unplug transformer from the wall or remove batteries.,
and use the ohm meter setting of the multi- meter to test for continuity of the switch when the switch is in the on position.
power must be off when using the ohm setting of a multimeter.
if power is on & using the ohm setting of the multi meter, you will blow out the multimeter. The ohm setting uses a 1.5 volt dc battery inside the multimeter to test for a compleated circuit.
so, 12volts dc would blow it out on ohms setting.
TESTING FOR OUTPUT OF FAN TRANSFORMER OR BATERY PACK.
If the switch is good,reinstall it on mr.heater and test the output of the transformer or battery compartment using the 20 volt dc scale of the multi meter. the voltage scale you select ,must be higher than the voltage you expect to find ,in order to avoid damage to the multi meter.
observe polarity,positive to red and negative to black.
the dc voltmeter setting is totally polarity sensitive and a reversed hook up could blow out the meter.
multi meter means it can read ac volts, dc volts,ohms and dc amps. Read and understand the included instructions before using a multi meter
a good single battery in new condition reads 1.62volts dc
1.5 vdc is almost dead, a good used battery reads 1.58 to 1.6 vdc
below 1.58 vdc is weak battery and 1.48 vdc is usually totally dead, but may be enough for momentary usage under 1 minute.
Sep 08, 2010 | Mr. Heater Big Buddy Heater
I need a 2x2 brushless fan model # rdm5015s dc 12 volt. where do i find one please?
Perhaps try Google's Product Search?
It appears to be a fairly standard 50x50x15mm fan with a two pin type 2 connector. Try looking for a two pin 50mm fan with a thickness of less than or equal to 15mm.
A quick search I've done can be found here.
May 10, 2010 | Sanyo /San Ace DC 12v Brushless FAN Assy
I have a 39 ford 6 volt battery operated car. I
you need a voltage doubler circuit which feeds from your 6V DC system and converts it to AC and steps it up and converts it to 12V DC. This device might be difficult to find. OR use a 6Vdc power inverter and just use a 120volt AC fan if much easier to source out in your area.
You might want to try a 12VDC high speed fan and see if the 50% reduced speed is already sufficient for you.
Aug 30, 2009 | 2001 Ford Escape
Need a new DC brushless fan
www.farnell.com is available in UK.
Dec 31, 2007 | LG RH177 DVD Recorder/HDD Recorder
Sunon (16-02-006) Fan Kit Logo
508 people viewed this question
Top Sunon Computers & Internet Experts
David Payne
David Payne
Are you a Sunon Computer and Internet Expert? Answer questions, earn points and help others
