Question about Dell Computers & Internet
The sentences on my PC display screen move in wavy fashion from below upwards. It Dell screen and has been working well for the last two years.I down loaded Registry Mechanic of PC Tool. How to rectify? Thanks
    Scholar:
  • 88 Answers
Have you tried to increase the screen's refresh rate? If you see some sort of blurring horizontal line that scrolls upwards, most of the time is that screen's refresh rate in your Display Settings are too low.
Posted on Jun 29, 2009
Latitude D830 starts then shuts down quickly.
1. Make sure you are plugged into A/C.. Your battery could be running low.
2. Make sure there is nothing blocking the heat vents. This symptom is typical for overheating processors.
Mar 17, 2013 | Dell Latitude D830 Laptop Computer PC...
I am at work right now looking for solution to my monitor at home. The screen is so wavy that I cannot read the text very good. My 5 year old plays on the computer a lot. And all of a sudden the other...
Connect the monitor to a different computer (laptop or desktop), to see if the problem "follows" the monitor.
Connect a different monitor to your computer, to see if the video-card in your computer is generating the "wavy" display.
Move any "power-bars" and PC Speakers *FAR* away from the monitor, to eliminate electrical interference.
Oct 22, 2010 | E-Machines eMachines Monitor E15T4
Screen upside down
Holding down CTRL and ALT while pressing the DOWN ARROW flips the screen upside down.
To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW.
You can also try CTRL-SHIFT and then “r” … this works for some Dell configurations
This problem can also be solve in some PC using the below technique.
In Control Panel>Display>Settings tab>Advanced button, look for settings relating to display or screen position.
Newer video cards have the capability to flip the display 90 and 180 degrees for use with LCD screens that can be rotated.
If the problem still persist, Start you PC with F8 key press, select "Last known good configuration that works"
it will most probably solve the problem.
Jan 20, 2010 | ASUS Eee PC 1000H Laptop
My laptop screen has a thin blue line going down, why has this happened?
You have the beginning of a failing Display panel, and will eventually need to replace the display.. you can hold the top left and right sides of the display screen-slightly bend forward and back, you should see the blue line either go away or it will produce more lines...
This is due to a short on the circuit board panel on the backside of the display panel that controls the Pixels on the Screen.. The Pixels are controlled In a Line Grid Fashion...
Nov 16, 2009 | Dell Inspiron E1505 Notebook
Monitor display is pinched at the corner
Check if the same thing happens under safe mode.
Safe Mode
Continue to press the F8 key when Windows starts to load
Or hold down the CTRL key
From the menu, select Safe Mode
Same thing? Then I have bad news for you. You need a new monitor. Best to verify for sure on another computer though.
Jan 17, 2009 | Dell Dimension 3000 PC Desktop
Vertical Wavy lines moving upward in my monitor
i think you have a faulty Fly Back Transformer { FBT / EHT }.
Mar 09, 2008 | Gateway FPD2275W LCD Monitor
Wavy scrolling
sounds like your screen settings need to be optimized for performance..go to control panel, system, advanced, and top panel should be visual performance. open that up and see which makes it work a bit faster.
check your computers warranty here 4 FREE
Mar 04, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Wavy or distorted monitor
Wavy or distorted issues only arise if electronics or anything that has magnets in it is near it or on the CRT ( the really huge monitors) so try moving it elsewhere ( In this case you can hire someone with the "magic wand " to zapp the colours back)(general tv repairer.If its an LCD (flat and small screen) it may be dying as the transistors are wearing out ( They usually last for 4 yrs) The only thing you can do is replace the circuit board or the panel . If you have another pc or laptop try to connect it to the monitor and if the pictures are perfect ,its your graphics card .
The best solution to this is to move the screen to another place without electronics or to connect it to a laptop or pc to see if its ok. If the symptoms persist i recommend you to buy another perferably dell screens 19" Lcd as they are cheap and provide good quality.
Sorry for the huge legnth of this Hope it helps :)
Dec 05, 2007 | HP VECTRA VL PC Desktop
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Computers & Internet Logo
234 people viewed this question
Alun Cox
