Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lens wont extend
I can look at pics and the battery is charged but it wont turn on and the lens wont extend.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 18, 2012
HeavyDLB
  • 46 Answers
SOURCE: Blank screen on camera when turned on...cannot take picture
Though there may be an alternate reason, It sounds as though you may be experiencing a failed CCD image sensor with your camera.
Try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have the CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
  • 57 Answers
SOURCE: Canon G10 wont turn on
Try removing the card first and then trying to power up the camera. Cameras often fail to turn on/off when a card goes faulty. Next I would try pushing the playback button, it also acts as a power button but starts the camera in playback mode. If this works it could indicate a problem with the power switch circuit itself. If there is still no sign of life I would suspect a fuse to have blown. They are internally located and very small, you would need to have a service centre try replace it for you. Good Luck!
Posted on Apr 15, 2009
SOURCE: Camera simply stopped working. lens extended and
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
if ur still unable to retract the lens....... ur lens motor assembly is broken and wud need replacement.
Posted on Aug 16, 2009
chelseawells
  • 11 Answers
SOURCE: will not turn on
This is likely the cause of an internal screw that has come loose, it's very common on the G9. A great place to get help with this G9 problem is: camerasandparts.com since they just specialize in these powershots. They not only have the fix available but they have the correction so this never comes back, that comes with their no power service for the G9's automatically. I hope that helps, that's the place if you need help with a powershot, best of luck
Posted on Jun 24, 2010
CameraParts4
  • 109 Answers
SOURCE: The lens is stuck in the extended position. When
Typical lens error. You will need a replacement lens.
Posted on Jan 23, 2011
Wont turn on and lens wont extend. Put in new fully charged battery but still nothing. Can hear motor but nothing works.
This is may be a camera battery problem or a lens error. Try Li-ion batteries first and see if anything better
May 19, 2011 | Kodak EasyShare P850 Digital Camera
My KODAK EASYSHARE M1033's lens will not extend.
your lense isnt extending because u need to charge your battery i gaurentee as soon as u let it charge it will extend once again
Jan 20, 2009 | Kodak EasyShare M1033 Digital Camera ...
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Lens wont move and camera wont power up
It's time for a new one, uneconomical to repair.
Jan 11, 2018 | Kodak EasyShare One Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Will not power on, lens stuck, poor warranty
my camra lens wont open what do i do emial me at crlsprkr@yahoo.com
Nov 07, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Can view memory card but wont power up to take pics
Try using brand new fully charged rechargeable batteries like NiMH or NiCd. Also try viewing though the computer via USB.
Sep 17, 2006 | Olympus Camedia Stylus 300 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
