Question about Toshiba Satellite L25-S119 Notebook
Hard Drive is Full
Using Sonic Record Now to copy DVD's through an external DVD Burner, now after making several copies of a DVD my hard drive on the laptop is full
  • 328 Answers
Check the settings on your Sonic Record Now. I think you have it set to copy data to your hard drive, look for this in the options menu. You should clean out all temp files too in case it is storing them there from the DVD sessions.
Posted on Nov 07, 2007
How do I transfer recorded movies to a external hard drive?
That depends. What device did you use to record these movies? If you recorded a movie using a DVD recorder, connect your external hard drive to a PC device which has a DVD rom. Go into the files, copy and past the file to your external drive.
Sep 15, 2016 | Hard Computers & Internet
How can I get permission to copy file from computer to my external hard drive
You should be able to copy and paste, or simply drag the file to the external hard drive (to make a copy).
Right click on the file, then select 'Copy'. Navigate to your external hard drive and then click 'Paste' to copy the file into it.
If you're talking about something like a word document you may have to change the permissions. To change the permissions right click on the file and then choose PROPERTIES. Change the properties if need be (the permissions..)
The image below is from my computer using Linux .. however the process is the same using Windows. Right click the file .. then choose Properties..
Jan 05, 2016 | Hard Computers & Internet
System not recognizing external device
I understand by "external device" is that your none of your USB ports work and you can't use your CD/DVD burner
Get a Hard Drive to USB connection, they are cheap and you can get one in any computer store, remove your HARD DRIVE from your Compaq and connect it through USB to your new computer. You can copy all your data and still continue using your old herd drive as an external drive.
Sep 28, 2013 | ADATA A-DATA Nobility Series NH92 500 GB...
Cd drive and burner are not working
Test the disc by using the command prompt to copy files loadTOCNode(2, 'whattotry'); Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive.
To test the disc by using a command prompt to copy files, follow these steps:
  1. Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files.
  2. Click Start, and then click Run.
  3. Copy and paste (or type) cmd in the Open box, and then press ENTER.
  4. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:\*.* HardDiskDrive:\cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder.
    Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files.
  5. If you are asked whether cdtest specifies a file name or a directory name, press F.
  6. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER.
    If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement.
Jul 05, 2010 | Microsoft Computers & Internet
My samsung 500gb external hdd is niether copying nor being format
you can do one thing remove the hard drive from the casing and put on some other casing then check, if the problem is the same then its the problem of hard disk
Oct 09, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
My dvd burner doesn't burn dvds
You need to check that with blank DVD's you are using compatible with your drive.Because the DVD's may work with your extranal drive but not with your builting drive. If this doen't slove the problem I would recommend using a different burning software other than "sonic record now" and "vista o/s Built-in dvd burner".
Sep 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Incompatible Disc Message
You need to use -R DVD disks, I used Maxell 1.4X speed disks wih no problem in a CU-VD10 berner. Hope this helps
Sep 01, 2008 | JVC Everio Share Station DVD Burner Burner
Dvd burner question
First off is the drive a read only drive or a Read/write drive? If you look at the front drawer check to see if there is a big RW(read/writable) on the front of the drawer. If it doesn't have the RW then you won't be able to burn discs. If it says RW then you will be able use it to copy DVDs. You accomplish this by using software to copy the disc you're interested in to your hard drive and then using the copy on the hard disc to copy back to a blank recordable DVD placed in to tray.
Jul 23, 2008 | Computers & Internet
Copying mini dvd to hard drive and then making copies
you need to make sure that you have the right software in order to do this. you also need a dvd burner and software.
Feb 14, 2008 | Panasonic VDR-D200 DVD Camcorder
LG vs Lite On
both are just the same features just to write file from your hard drive. Maybe your point is you want the video from your VHS tapes will transfer to your hard drive. The only way to copy the video from your VHS is you need an external VHS player at the same time it will record the running video to a soft copy.
Please check this maybe this will be helpful
Please rate me solve if you like my solution.
Best regards,
Oct 31, 2007 | Lite On (ldw811s) DVD±RW Burner
Toshiba Satellite L25-S119 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
