Question about Amana ARB8057C Bottom Freezer Refrigerator
The freezer is not getting cold enough to freeze anything, and the ice maker is no longer working.
  • 52 Answers
Have someone check your refrigerant levels, I suspect a possile leak.
Posted on Jun 29, 2009
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/gramps_bab85ce284d72c1d
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Why won't by ice maker make ice?
The icemaker will not harvest if the temperature isn't cold enough. this may be why you are not getting ice.
Oct 04, 2014 | Frigidaire FRS6R4E Side by Side...
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Maytag side by side, msd2456de will not make ice, I have water that dispenser works fine, I believe freezer is cold enough what could be the probem?
If water is not getting to the ice maker the fill ice maker with tap water. Wait until it freezes and dumps and then replace the dual water control valve on back near floor. Sea Breeze
Jul 20, 2009 | Maytag MTB1504A Top Freezer Refrigerator
Undependable freezing - sometimes will, sometimes won't!
High room temperatures will throw this unit off BIG TIME. Just to give you an idea how sensitive the freezer bowl is - if you run cold water along the freezer bowl before putting your ingredients in, the COLD water is enough to unfreeze the bowl! Don't remove the freezer bowl from freezer until you are immediately ready to begin mixing - not 5 minutes earlier.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
No Ice
Clogged filter?
On most ice makers, if the water pressure drops too low, the valve will not open to fill the ice maker.
Frozen water line?
On some units, the water line supplying the ice make can freeze up preventing water from getting to the ice maker.
Freezer cold enough?
Are you sure of the temp inside your freezer?
Place a small thermometer that can register temps around the freezing range. (example of a thermometers not to use are: a candy thermometer or a thermometer used to take a person's temp.) If you do not have one or do not want to purchase one, put a bowl of water in your freezer. If the water does not turn to ice in say 6 to 8 hours, your freezer is not cold enough.
Feb 21, 2008 | Refrigerators
Amana ARB8057C Bottom Freezer Refrigerator Logo
99 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
