Question about Clarion MAX385VD Car DVD Player
Park brake switch
I just bought a clarion MAX385VD dvd player and havent installed it yet due to this "parking brake ground wire". do you need a toggle switch hooked up to ground to allow it to play or can you just hook it straight up to ground 24/7 and it not hurt the head unit??
  • Anonymous Mar 20, 2014
    cause i never hook one up and i am curious what all wires i need to hook it up
  • 49 Answers
If you have the old firmware then all you need to do is ground the parking brake wire..
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Posted on Jun 29, 2009
What color is the e brake wire on clarion max385vattempting to overide the park brake issue so I can watch dvd's car is a 98 Camry
The most common way to solve this is to ground the E Brake wire and the deck thinks the E Brake is always on. if that fails you may have a somewhat smarter deck and may have to go to plan B.
This is a common solution to bypass the e-brake screen,
1st you will need to purchase a 12 volt or above Momentary Push Button/(Toggle)switch (about $5 Radio Shack)
2nd Using the Diagonal Pliers adjust the length of the Radio's Emergency Brake Wire to your desire. Make sure you have enough wire so you can mount it where you can easily access it like beneath your steering wheel/ on the Dash Board.
3rd Connect one end to the emergency brake wire from the radio and then connect the other wire from the switch to a ground to your car. You can use the same ground connection that you used for the radio and it will be fine. Make sure you wrap up the wires using the Electrical Tape to prevent shorts.
4th (Using Button Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just press the button (4x Times)for one second and release it. On The fourth time the screen takes about 6 second to display the video.
5th (Using Toggle Switch) When you are ready to use the DVD player insert DVD and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just flip the switch on and off (4x Times). On The fourth time the screen takes about 6 second to display the video.
Hopefully this helps.
Jan 22, 2011 | Clarion MAX385VD Car DVD Player
How to by pass parking brake
Find the wire for the parking brake... Get a (interrupter) toggle switch. Ground one side of the switch to a grounding point in the vehicle close to where you are gonna have it. Hook the wire for the dvd up to the other side of switch....When you want to watch dvd, flip toggle switch...
Nov 11, 2010 | Clarion NZ409 Car DVD Player
Where can I get a wiring diagram
here we go
yellow +12v main power
black is ground
red +12v accessory
blue/white amp turn on
orange/white illumination
blue auto antenna
brown phone interupt
grass green park brake(but if you want to watch dvd's while u drive connect this to the ground)
now speakers
fr right+ gray
fr right - gray/black
fr left+ white
fr left - white/black
rear right+ purple
rear right - purple/black
rear left + green
rear left - green/black
hope this helps thumbs up pls
Aug 11, 2010 | Clarion MAX385VD Car DVD Player
I have a clarion max385vd and i want to bypass the parking brake. How do i do that the easiest way?
you locate the grass green wire and connect that to the earth and presto you can watch dvd's whilst u drive
hope this helps pls rate people havent been rating
Aug 04, 2010 | Clarion MAX385VD Car DVD Player
Display is locked and is asking for a four digit password?
disconnect from power for 30 seconds and you will need to disable the park brake shut off buy grounding the brake wire for 2 seconds then off .. you will have to do this everytime you want to drive with this system .. i have seen people put a toggle switch inline with the brake wire and click it on and off to make the stereo work ... i hope that helps .. and remember in most citys its illegal to drive with a monitor in the front of the automobile
Feb 10, 2010 | Clarion MAX385VD Car DVD Player
I need the wiring diagram for this deck. Which wire is the one for the parking brake?
i need the wireing diagram for this deck which wire is the one for the parking break
Nov 30, 2009 | Clarion MAX385VD Car DVD Player
I just got a vehicle that has the MAX385vd and won't play video
Do you mean it has this warning all of the time? If so, it is not wired properly, or there's a short not allowing it to read that it is in park and the parking brake is on.
May 27, 2009 | Clarion MAX385VD Car DVD Player
How do i bypass the parking brake switch in order for my video to play
I think the wire that should go to your hand brake is green, all you need to do to bypass this is hook it to an earth.
May 06, 2009 | Clarion MAX385VD Car DVD Player
No video
all u need to do is run hand brake wire to a on off switsh and then ground when dvd playes u flick switch on and it trips screen mine works great
Mar 23, 2009 | Clarion MAX385VD Car DVD Player
Clarion MAX385VD Car DVD Player Logo
697 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
