Question about Belkin Wireless G Router F5D7230-4 - Wireless router + 4-port switch - EN, Fast EN, 802.11b, 802.11g
I set my 7230v7000 to an access point by accident and the reset button is not restoring the router to factory settings. How can I get to the settings page so that I can change it back...
  • 390 Answers
Try starting at 192.168.1.1
also when you are resting the router first disconnect all connections and and the power connections leave it for about 1 min then hold the reset button for approx 20 secs then connect the connections ack to check
hope this helped
cheers
pls rate the solution, thanks
Posted on Jun 29, 2009
How do I restore my router to the factory setting? I have no Wi-Fi service.
Restoring the Default Configuration and Password
  • Use the restore factory settings button on the rear panel of the router. Use this method for cases when the administration password or IP address is not known.
  • This is how to restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1.
  • To use the restore settings button:
    1. Locate the restore factory settings button on the rear panel of the router.
    2. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button for about 5 seconds, until the Power light begins to blink.
    3. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green.
    4. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
      Then you can go through the setup procedures to setup your wireless
      Here is the link to the documentation so you can set it up again
    WNR2000 Manual Table of Contents
    hope it works for you
    Sep 10, 2014 | NetGear WNR2000 Wireless Router
    Reset to default config
    Try by pushing the reset button behind your router, it will restore to factory level setings.
    Mar 11, 2014 | Computers & Internet
    I dont know wat is my username and password , then how can i change my network key
    you might have to restore it to its facory settings
    restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
    You will lose all of your personal settings if you restore the factory default settings.
    You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
    hope this helps
    Oct 09, 2012 | U.S. Robotics USRobotics USR5451 Wireless...
    Need password to my netgear router n 300
    what is the model #?
    Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
    If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
    If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
    Mar 02, 2011 | Computers & Internet
    I forgot my WEP password
    On the back of the router there is a reset button or a pin-hole. Hold that in for 8 seconds and that will reset all your wifi settings to default. At that point there will be no password and it can be setup like new.
    Feb 28, 2011 | U.S. Robotics (USR5450) 802.11g/b Wireless...
    I have a belkin f5d723-4 router that i accidentally set as a direct access point. Now i cant access the routers home page. Is there a way to reset the router?
    Check on the back for a small hole you can stick a straightened paper clip into.
    The "Reset" button is used in rare cases when the Router may function improperly. Resetting the Router will restore the Router's normal operation while maintaining the programmed settings. You can also restore the factory default settings by using the "Reset" button. Use the restore option in instances where you may have forgotten your custom password.
    a. Resetting the Router Push and release the "Reset" button. The lights on the Router will momentarily flash. The reset is complete in 60 seconds.
    b. Restoring the factory defaults Press and hold the "Reset" button for at least 10 seconds, then release it. The lights on the Router will momentarily flash. The restore is complete in 60 seconds.
    Jan 16, 2011 | Belkin F5D7234-4 Router
    I am using DLINK DWL-7100 Wireless AirPremier Access Point in unsecured mode. I cannot reach the logon page to enable security (192.168.0.50). Just keeps timing out.
    To secure the router, first you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.50 (default) The default administrative user name and password (unless you've configured otherwise, the default username is admin and bno password). If you cannot access it wirelessly, try accessing through wired connection. Otherwise, you can simply resetthe router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings wouls be restored.
    Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
    Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
    Feel free to contract me for further assistance
    CreativeTECH
    Dec 31, 2010 | D-Link AirPremier DWL-7100AP Wireless...
    Dwl-2100ap d-link wireless access point. I want to reset my device, I have forgotten my PWD and Log name.
    First, to reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router on the right hand side to the DC Power Jack). The LEDs will then blink and the routers factory settings wouls be restored.
    GoodLuck!
    Dont forget to appreciate the solution if I could have been of any help!
    CreativeTECH
    Dec 10, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
    Its because it got reset accidently and then how would i restore it back again. or can it still be restored back??
    Sorry you will have to set it up again
    Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
    hope this helps
    Dec 05, 2010 | NetGear WG602 802.11g/b Wireless Access...
    On belkin surf router clicked on set as access point. then i tried to change it but my computer cant get internet from the router so i cant access the belkin homepage. can u help
    the only thing you need to do is reset your router to go the IP address original 192.168.2.1
    because when you setup it as a access point the router change the Ip Address.
    restore the router to factory default settings, please do the following:
    1. Unplug the router's power supply
    2. Press and hold the reset button on theback of the router
    3. Keep the reset button depressed and, at the same time, plug the power supply back in
    4. Keep the reset button depressed for another 10 seconds
    5. Release the reset button
    do this for 3 times and you will acces your router.
    Good luck
    Please rate me techbelkin
    Aug 02, 2010 | Belkin Wireless Surf Router (F7D2301)
    Belkin Wireless G Router F5D7230-4 - Wireless router + 4-port switch - EN, Fast EN, 802.11b, 802.11g Logo
    37 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
