Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
I have a Canon camera, which worked fine. I had to recharge teh batteries often, that was all. Last night, i took it out. In view mode, the camera does not shut off. The moment i switch to camera mode, the lens opens out and then the camera shuts off. What do i do pls? Any help appreciated
I'm assuming you're talking about a point-and-shoot model, and not the 1000D as the category suggests. Camera mode has significantly higher power requirements than viewing mode. It is possible that your rechargeable battery has degraded to a point where it no longer can power camera mode, or it might just be discharged. Try with a freshly charged battery, or if you're lucky enough to run on AA batteries, get new ones. You might also try using the camera while plugged into the USB port of the PC, which might be able to supply power to the camera. I have noticed that when the batteries are near-empty, the camera "dies" rather abruptly.
Posted on Jul 01, 2009
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
Jul 13, 2009 | Canon FS100 Flash Media Camcorder
I bet you can't solve this.
We have a Canon A520 and it was having all the symptoms noted. Searched for a resolution on numerous sites including the Canon Support site. While on the Canon Support site, I found an FAQ on "How to RESET the A520". Turn camera on, find and hold MENU button for 5+ seconds until "Reset settings to default?" screen appears. Arrow over to OK and press the SET button. When we did this the battery low indicator showed, replaced batteries with standard alkaline batteries. Everything functions properly, with no additional problems for the past 5 days. I guess the camera just lost its mind and had to be defaulted and rebooted, hope this helps.
Oct 01, 2008 | Canon PowerShot A520 Digital Camera
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Canon S2 problems
Low battery power ? (rechargeables do not last forever).
Try a brand new set of batteries
Feb 06, 2008 | Canon PowerShot S2 IS Digital Camera
I have a samsung digimax 201
Digital cameras in general use massive amounts of power to supply their internal electronics and that big, beautiful, bright LCD view screen.
We switched to 2500ma NiMH rechargeable batteries. At first they would barely work, about 25 shots and they would die, after 5 to 10 discharge/ recharge cycles though, they now work great. I recharge them every night and like to leave at least one set on the charger all the time to keep it 'topped up'. Most chargers have this feature, ours even has a built in fan for when the batteries get hot (they do on fast-charge mode).
Now the rechargeables work great, we recently went to a race for my daughter and took 1.5 gigs of photos and movies on one set of batteries! Amazing, considering with standard AAs, we would get about 6-10 minutes of 640x480 movies on a set of batteries.
Our rechargeable set is a cheapo Walmart close out (got it for $15- four batteries and charger!) by Digital Concepts.
Hope this helps,
Russell - Idaho USA
Feb 03, 2008 | Samsung Digimax S730 Digital Camera
Canon will not power up.
This will happen when the batteries are dead. Please replace or recharge. The lens will not go back in until you restore power.
Jan 01, 2008 | Canon IXUS i7 Digital Camera
CAMERA WILL NOT TURN ON
Try new good quality batteries.
i experienced this issue last night. Even after replacing the batteries i had the same problem though the batteries were from a very cheap pack & i'd had them a while. The camera worked fine once i'd recharged my normal batteries. I'm no expert but I expect switching the camera on must use much more power then review mode causing the camera to switch off before it has time to tell you your batteries are low.
Hope this solves your problem!
Sep 03, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
Battery?
i just got mine today, and the batteries were dead withtin a couple of hours, so yes. mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
Aug 24, 2006 | Samsung Digimax S500 Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
124 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
