This can be a few things. first try and cold start it.
1. Take out the battery leave it pluged in. hold the power button for 5 sec. then release. turn on system normaly once in windows shut down. replace battery. turn back on. that should work.
2. You have a bad driver problem trying loading into safe mode hit F12 and select safe mode if it loads with no problem then it could very well be a driver or software problem
3 if nether of them work then you have a hardware problem which could be causing overheating.or just a device going bad.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite M35X-S309:
I need to restore factory default setting for my acer aspire 5920? Can you tell the steps in a...
(More)
I need to restore factory default setting for my acer aspire 5920? Can you tell the steps in a layman language?
Hi,I have a IBMtinkpad R40 laptop with windows xp SP2.Recently suddenly I got BSOD error:...
(More)
Hi,I have a IBMtinkpad R40 laptop with windows xp SP2.Recently suddenly I got BSOD error: STOP:7E(0xc0000005,0x8735f4c9,0xf7b42c50,0xf7b4294c) Then I try to go in safe mode but I checked none of the booting optionsare working showing the same blue screen error at startup.My systemhaving PC doctor,so I did a diagnostic full test,the result passedeverything except '' modem dialtune failed''.I don't know whether thismaking my system dead or not?Also I checked there is no mini dumphappened. My system is not having any CD driver,but the recovery console isinstalled.So I tried with that ,did the CHKDSK /R.Result is every thingfine,no bad disk.I really dont know how to do other repairing inrecovery console. where is the problem? I tried another option to go into my drive,thats the NTFS Active bootdisk(demo version).With this I tried the same chkdsk /F.Result :noerror. I checked through the file recovery tool,to see what time the problemhappened and any file/folder modified/deleted.thats also seems ok.Sopls help me how to troubleshot my system.Is it possible to make changeany system file through Active boot,so that my system will bootnormally? I dont want to loose anything as I don't have the original OS CD with me.. I did the system restore part,that also failed. Appreciate any quick response
Need ALL Drivers to a ADVENT 5544 NO Laptop.Has Windows XP Home installed.Well,,nothing else...
(More)
Need ALL Drivers to a ADVENT 5544 NO Laptop.Has Windows XP Home installed.Well,,nothing else works,no usb sockets,soundcard etc.
lost all my sony files off my laptop so got 3 recovery discs off sony.Download ok but on recovery...
(More)
lost all my sony files off my laptop so got 3 recovery discs off sony.Download ok but on recovery stop short with the error 63,also theres a clicking noise only at the end.
