Question about Sony Cyber-Shot DSC-P92 Digital Camera
No image my camera works as far as viewing what is on the memory stick, and settings can be changed also however there in no screen image when you try to take a picture and when you do the image is just black.
  • Anonymous Dec 12, 2007
    i have a sony cyber-shot 5.0 digital camera. i cant view pic's but cant see anything when i try to take a pi from view finder or lcd screen. it show battery life and other stuff. like reading a news paper. i should be able to see what im taking a picture of.
  • marybond Jul 13, 2008
    It worked fine until i transferred pics to computer and then deleted from memory stick. Then i recharged battery and lcd always black screen. I tried to reset camera , and recharge camera but no luck. Any suggestions about fixing. I had this camera fixed for the same problem under warrenty but it seems that this is a reoccuring problem.
  • Sony Master
  • 4,738 Answers
Definitely sounds like a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Posted on Nov 17, 2007
The vids on my Sony DSC-T90 won't play and I can't record. The camera says' "file error"
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Not able to record or play :
This error may occur in any of the following circumstances:
-The Memory Stick® media is not inserted properly.
-The Memory Stick media is not supported for use with the camera.
-The Memory Stick media may be faulty.
Mar 13, 2011 | Cameras
How to save a picture to a memory stick,,
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Dec 04, 2010 | Sony Cyber-shot DSC-T2 Digital Camera
Images can be viewed on camera but not on PC after downloaded.
Memory stick sounds bad in this problem, try another memory stick and Initialize (reset) camera through option in home/ menu.
Hope this will solve problem.
Oct 11, 2009 | Sony Cyber-shot DSC-T500 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
File error Sony Cybershot DSC-W120
The LCD screen may display a FILE ERROR message when trying to view a still image on the Camera if the image was rotated, modified and overwritten using editing software on a Computer.
To play images you have taken on the Camera, it is recommended that you do not make any changes to the original image files.
It seems that the images are rotated or modified in the Computer.
Check the link give below:
Aug 31, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Memory sticks empty and shows no memory available
i have a solution that worked! Notice: save all the needed data on your computer, because Formatting your Memory stick will wipe everything out!
if you have a Sony PSP, or know someone who does, replace the memory stick that says "no memory Space" in to the PSP port, go to "Settings" which is the left-most section of the PSP main screen, then scroll down to "System Settings," select it, Scroll down again to the "Format Memory Stick" selection and press "X" follow on-screen instructions and  SHAZAM!  its ready for action in your camera again!
Nov 16, 2008 | SanDisk Memory Media
No image
79da3bf.jpgWhile in picture taking mode, press that button. It will restore your viewer.
Nov 20, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Image zone plus
tell me camera model & if it having memory stick or not if ur havinf it then u can transfer it from memory stick also
Oct 15, 2007 | Microsoft Windows XP Home Edition
Cant View Thumbnails on Camera
you can delete images from the 'stick' on computer- so long as you do not format on computer.
Mar 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Cyber-Shot DSC-P92 Digital Camera Logo
78 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
