Question about Panasonic Lumix DMC-FZ8 Digital Camera
Inoperative Panasonic Lumix DMC-FZ8
Camera when turned on asks for the lens cap to be removed and press right arrow. Despite doing this instruction returns and camera will not operate at any level
I had this issue and found a small grain of sand around the lens. On removing it the camera worked fine again.
Posted on Jul 13, 2009
How do I set the date on the Panasonic Lumix DMC FZ 8 camera? If you can't answer, where can I find an online manual for this camera. Thanks a lot
Operating Instructions. Digital Camera. Model No. DMC-FZ8, check this link panasonic.com/OPERMANPDF/DMCFZ8.PDF or click over next image...
Good luck (remember to rate this answer).
Aug 31, 2011 | Panasonic Lumix DMC-FZ8 Digital Camera
Hi i have a Panasonic Lumix DMC-FZ8. How do I
This should help
Press [ menu set] to display the [PLAY] mode
menu and select the item to set.
You can copy recorded picture data from
the built-in memory to a card or vice versa.
1 Press up/down to select the copy
destination: (in to card) and then press
[MENU/SET].
Jun 17, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Using instructions required
You can download the Panasonic Lumix DMC-FZ8 Manual ( Operating Instructions) here:
Panasonic Lumix DMC-FZ8 digital camera Operating Instrutions (10.7MB)
Have fun :)
Apr 18, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
I have an FZ7, so the following may or may not work with the FZ8:
Turn on the camera. Press the button labeled "MENU SET".
Then press the left arrow button and the down arrow button.
Now press the right arrow.
In the menu that comes up, scroll with the up and down buttons until an ICON OF A PERSON TALKING becomes visible. The icon is to the left of the menu item's name.
Select this menu item by highlighting it, and then press the right button. Now you can select the desired language.
Jul 09, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
ERROR REMOVE CAP LENS
I had the same problem with mine after I dropped my camera when it was opening up after turning on. It feel directly on the lens and ever sense has told be to remove the lens cap.
I’ve disassembled the camera and discovered that the zoom motor drive assembly has a small set of plastic gears inside that are quite fragile and like mine are easily broken. You’ll find the zoom motor after taking the back assembly of the camera off. It’s located on the bottom left side of the lens assembly if you're looking at the camera as if you were taking a shot.
Here’s the part no. from the Panasonic support web site.....
L6DAAAHB0001
ZOOM MOTOR
46.07
May 28, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Remove Lens Cap
We had the same problem with our FZ8. My wife had dropped it and it must've knocked the lens barrel sensor out of whack. I searched google and found a suggestion saying this message occurs when the lens barrel is out of alignment. (http://www.fixya.com/support/t186189-some_reason_camera_keeps_comming_up)
With the lens barrel out, I gently pushed the barrel up, down, left, right and put a little pressure in. Somehow, the barrel worked itself into the right position! The camera works perfectly know. Its worth a shot to save $$$. Be gentle!!
Dec 26, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
LCD showing "remove len cap and press reset button" always
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
Jan 15, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
383 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
