Question about Intel DG31PR Motherboard
Can't install windows server 2003 - Intel DG31PR Motherboard
  • Sid869
    Sid869 May 11, 2010
    What error does the disc show
    Brigadier General:
  • 7,191 Answers
Microsoft Windows Server 2003 is not supported on your motherboard. For list of supported OS, visit:
http://support.intel.com/support/motherboards/desktop/sb/CS-008326.htm
Hope this answers your query. Thanks
Posted on Jun 29, 2009
I have a dell power edge t300 server. i need to install windows 2003 server. i dont have dell cd for windows 2003 server. while installing the hard disks (scsi) are not detected and setup aborts. how can...
If your Dell server cam with the Windows Server 2003 software, you should be able to order a replacement cd. Go to http://www.dell.com/support If the software was not packaged with the server, you will have to buy it at http://www.microsoft.com/sales
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 23, 2011 | Dell PowerEdge T300 Server
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
Hi
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
(msdn.microsoft.com/en-gb/library/aa366778.aspx)
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
Hp ml350g4 p server hang on diagonestic screen, unable to set standard boot order(ilo)
To repair your installation of Windows, follow these steps:
1. Insert the Windows Server 2003 CD in the CD-ROM or DVD-ROM drive.
2. If the Windows CD displays the What would you like to do? menu, click Exit.
3. Turn off your computer, wait ten seconds, and then turn your computer back on.
4. If you are prompted to start your computer from the CD, do so.
Note You must be able to start your computer from the Windows Server 2003 CD-ROM to run Windows Setup. Your CD-ROM or DVD-ROM drive must be configured to do so. For information about how to configure your computer to start from the CD-ROM or DVD-ROM drive, see the documentation that is included with your computer, or contact your computer manufacturer.
5. After Setup starts, press ENTER to continue the setup process.
6. Press ENTER to select the option To set up Windows now, press ENTER. Do not select the Recovery Console option.
7. Press F8 to accept the licensing agreement.
Setup searches for previous installations of Windows.
* If Setup does not find a previous installation of Windows Server 2003, you might have a hardware failure.
Hardware failures are beyond the scope of this article. See a computer hardware specialist for more help or try the Hardware troubleshooter. For more information about the Hardware Troubleshooter, see the Windows Server 2003 Help topic "Using Troubleshooters."
* If Setup does find a previous installation of Windows Server 2003, you may receive the following message:
If one of the following Windows Server 2003 installations is damaged, setup can try to repair it. Use the up and down arrows to select an installation. To repair the selected installation, press R. To continue without repairing, press ESC.
Select the appropriate Windows Server 2003 operating system installation, and then press R to try to repair it.
* Follow the on-screen instructions to repair the installation.
Notes
o You might have to change the boot drive sequence in your BIOS settings to successfully start your computer from the Windows Server 2003 CD. Contact the manufacturer of your computer, or see your manufacturer's documentation, for more information.
o If you cannot start your computer from the Windows Server 2003 CD, you might have a CD-ROM or DVD-ROM drive failure or other hardware failure.
o After you repair your Windows Server 2003, you may be required to reactivate your copy of Windows Server 2003.
Jan 22, 2010 | HP Compaq ProLiant ML110 G4 Server
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Mar 15, 2009 | Intel D101GGC Motherboard
I am unable to install sql server 2005 in windows server 2003. how to upgrade this to windows server 2003 sp2(x86).
You can download Windows Server 2003 (SP2) from following link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=95ac1610-c232-4644-b828-c55eec605d55&displaylang=en
Thanks.
Mar 03, 2009 | Microsoft Windows Server Standard 2003 for...
Step by step installing of windows server 2003 & its application features.
Windows Server 2003 installation is very much like the standard Windows installation, except you will be prompted with services options.
Depends on what you need - view guides here.
Dec 07, 2008 | Microsoft Windows Server Standard 2003 for...
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
May 29, 2008 | Microsoft Windows Server Standard 2003 for...
Intel DG31PR Motherboard Logo
175 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
