Question about Coleman Mach III Air Conditioner
A/c won't start
When I turn the a/c on it only humms and then shuts off. If I start the fan first it will blow air fine but the compressor still hums and shuts off
  • 1 more comment
  • j_typner Jul 01, 2009
    no a rv un it coleman mach 3
  • Jeff Myers May 11, 2010
    When you start the fan first, the compressor hums and shuts off but does the fan shut off as well? Does the compressor try to kick back on after a couple of seconds or does it stay off until you recycle the unit? What kind of thermostat do you have, wall mounted or manual control? When say you start the air and it only humms and shuts off, does it trip a breaker, does the fan motor come on?
  • FunnyPlumber
    FunnyPlumber May 11, 2010
    Is this a residential central air conditioning system?
Need wiring for conpassor
Posted on Jul 30, 2009
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
My ac comes on in my RV and runs for a about 15 minutes and then the fan shuts off and finally the compressor shuts off. this happens before reaching the cooling temp. When it comes back on the fan does...
The Fan topside , Is the one working? The one that blows on the condensor? If not, your compressor can be trying to start against high head pressure. Ck the other fan, not the one that blows inside, the other one.It cools down the condensor and if the pressure is too high it will hinder the compressor. Good Luck
Sep 12, 2009 | Heating & Cooling
Have a duo therm penguin heat pump a/c when turning it on the compressor humms but no fan. the fan gets pretty hot upon the roof after 20 sec of operation. the main hot wire to the unit is pulling 18.5...
check the cap for the fan. Will the fan start if you spin it when you hear the humming. Check the lock rotor amperage for the compressor to see if it is hung up. The cap if it is shared could knock out both the fan and comp so check both.
Aug 12, 2009 | Heating & Cooling
Unit is running, but is no longer cooling. Fan is blowing, but air is not chilled (or cold). Unit has been running fine until a couple days ago. It has been turned off for the last 12 hours and tried...
not sure if it is a package system or a split but this is what you do.go outside where your outdoor machine is, after it has been shut off for awhile, and you should hear 2 distinct noises.1 is the outdoor fan, you should see it spinning.the other is a comppressor hum.some compressors have noise bags on them so listen closely thru the fan noise.if you hear no hum listen for a hum about every 2 to 5 minutes.if you hear this hum every so often, chances are you compressor is seized or stuck.the only thing to do there is get a tech and try a big boost to get it going.
Aug 07, 2009 | Fedders A6P09S2A Air Conditioner
Compressor switches on but only humms fan does not spin
You have a bad run capacitor. You can change it or you can get a service tech to change it. About 150 for the job Rus
Jul 19, 2009 | Heating & Cooling
Hitachi EC12 Compressor- weird hum
The burst of air you hear as the compressor shuts off is the cylinder unloading so it will not have to restart against a high pressure load. If the unloader is electrical it would explain the hum that you hear. This could be a normal function.
Aug 24, 2008 | Hitachi EC12 Portable Electric 2hp Air...
AC keeps blowing fuses
Fuses are a protection device and I guess that this is for the condenser section and compressor. If they blow right now when it is turned on would indicate that there is a short in the wiring or motor or compressor. If it trys to start and the outside fan starts and the compressor just humms and blows fuse, you have a locked compressor. Might check run capacitor or install a hard start kit and see if it will brake it loose, if not bad compressor
May 31, 2008 | Ruud UBHC Air Conditioner
Coleman Mach III Air Conditioner Logo
342 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
