Question about Dryers
WHIRLPOOL LAUNDRY DRIER.NO HEAT DURING DRYING
OPENED THE BACK, AND FOUND THE HEATING ELEMENT. ITS INTACT, BUT SEEMS TO HAVE ONLY ONE WIRE ATTACHED. THE OTHER TERMINAL HAS NO WIRE! POWER IS GETTING TO THE ONE WIRE, BUT WITH NO WIRE ON THE OTHER TERMINAL, IT CAN'T COMPLETE THE CIRCUIT. WAS HEATING FINE EARLIER THAT DAY; COULD THE WIRE HAVE BEEN ''SUCKED UP'' SOMEPLACE? HOW DO I FIND THE WIRE TO REATTACH?
  • 82 Answers
Sometimes it raps around the pullys or moter pulley it should be a neutral feed
Posted on Jun 29, 2009
How do you turn up the heat on the dish washer drying cycle?
There is no way to turn up the heat of the dishwasher during the drying cycle. As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. But you can do these things to help with drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation during the dry cycle.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. That problem can be caused by a bad heating element, or by a bad controller.
Sep 21, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher stuck in cycle
I found this:There are are 2 stats, hi limit and operating. You should find them attached to the pump housing. It gets a little tricky but the problem will boil down to one of the stats is bad or the heating element itself is bad [or something like a wire burned off at the element which will be obvious]. It can get a little tricky. I would start by checking to see if the element gets hot during operation. If no, ohm test the element itself. If ok, ohm test the high limit stat, it should be closed at room temp. If ok, try bypassing the operating stat and see if the element now gets hot during operation.
Read more: http://www.doityourself.com/forum/kitchen-laundry-large-electric-appliances/386770-whirlpool-dishwasher-gets-stuck-cycle.html#ixzz1kDTDjTm7
Jan 22, 2012 | Dishwashers
Whirlpool dryer model geq8858jq1.had a slight burning smell.cleaned the vent hose all the way outside and inside unit.smell decreased but then lost heat.found thermal cutoff opened.replaced and ran for...
Yes Thrmostat is bad "stuck" closed circuit will not open to stay at safe temperature. This can be dangerous. I never run my own machine at home unattended or while asleep. For fear something like this could happen and cause a fire had a recent problem with a Whirlpool. Replaced it after finding the "correct" one. I would bring the bad one with you when you go and get a new one.
Please leave a good feedback for me on here.
as i am trying to help people on here for free.
Jan 06, 2011 | Whirlpool Dryers
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
No heat
If there is no heat during drying cycle, it is usually either the heating element, or a thermal fuse.
See the following suggestions from repairclinic:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 19, 2008 | Splendide 2000S Vented Washer/Dryer
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
Leb6200 wont completely dry clothes first time.
the problem is most likely an airflow problem. if you have a flexible duct connected to the back of the machine then replace it with a smooth rigid (not pvc) metal duct. clean inside the wall or wherever the air goes to get outside (must be smooth metal at least 4" in diameter) in the wall, without too many bends. the electrical arc you spoke of would not have an effect on the heating element unless the machine is not heating at all.
Jul 04, 2008 | Whirlpool LEB6200 Electric Dryer
NO HEAT
On the back, lower right side of the dryer is an access panel to get to the thermostat and heating element. Be VERY careful of the sharp edges, they will cut with NO warning. Look at the heating element and verify that there are no breaks in the wire. If they are intact, I suggest replacing the thermostat. It is a fairly inexpensive part and can be found at www.partstoday.com. Let me know please if there is anything else I can for you.
Mar 30, 2008 | Dryers
Dryers Logo
Top Dryers Experts
