Question about Lexmark C533DN InkJet Printer
My CD disk on my computer doesn't open. I bought a new printer a X2600m and I can't install the software.
  • 390 Answers
Hi
if the CD drive is stuck and wouldn't open the trick is that there is a small pin hole on the front side of the drive take a long pin and push it inside till and drive door comes out till about 1cm or so and is free to pull the rest freely
i suggest that u get the drive tested before place any other CDs in there again
hope this helped
cheers
pls rate the solution if it was any help
Posted on Jun 29, 2009
    Problem Solver:
  • 12 Answers
Your CD Drive lens may not be working correctly
Izaakzakei cant get my printer connected to my laptop i have downloaded the driver but its still not working
You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control panel...click on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then next...you computer should install the hardware for you printer.
After installed, restart again...to see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
Sep 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Lost software to printer
You can download software from HP website, I will give you the link
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Have windows 7 on new computer, installed Adobe Pagemaker which is fine but want to turn files into PDF format, message say's no printer driver installed. Have tried to install but windows will not let...
the printer will need to be installed in compatibility mode....un-install the printer from control panel.
pain in the **** i know, but least you'll know from now on, how to install older programs & drivers in to windows 7....
if your installing from a disk, then put the disk in, then when the auto run box comes up, close it...
open computer instead from the start menu.
right click on the cd drive with the disk in, & select open.
drag & drop the contents of the disk on to your desktop....make a new folder to put it all in, if you need to.
then once it's copied across, right click on the install/application icon.
from the top of the menu click "check compatibility" if you dont see it,click off it & then try right clicking on it again untill you see it.
windows will scan & set itself to the right settings for that program.
then click try recommended settings.....followed by START PROGRAM.
if it all installs ok click next then click YES KEEP THESE SETTING FOR THIS PROGRAM NEXT TIME.
then go to the printers web site & update it with the latest software,thats if windows doesn't do it for you.....TIP:(white flag @ bottom right of screen)
do this with all older software.....windows 7 is **** hot when it comes to running older programs, im using a windows 98 program call photo express on mine...no problem.
GOOD LOOK MATE.
Sep 10, 2011 | Computers & Internet
I bought the HP Deskjet 5650, but I'm not sure how to install it to my home computer.
First find the installation disk that came with your printer in the box. Install the software by placing the disk in your CDROM of your computer and then follow the instructions on the screen. when the software has finished installing, connect your printer to the computer with your USB cord and the computer will automatically do the rest.
Some operating systems already have the driver for your printer and the software is not necessary. To check and see if your computers operating system already has the necessary drivers, just connect your printer via your usb cord. Your computer will recognize the printer once the cord is connected and you will see a pop up message around the right hand corner of the monitor screen that says "new equipment detected" and the computer will do the rest.
Nov 11, 2010 | HP DeskJet 5650 InkJet Printer
Have a new lexmark x2600 printer and cannot get it
install first the cd installer of the printer...
...do the set up process until they completely finish..
x2600 is compatible to Vista..
Oct 23, 2009 | Lexmark X2600 InkJet Printer
When i am trying to install my printer the wizard can't find the printer. there doesn,t seem to be anything on the instalation disc, when i open it in " my computer" nothing appears
The installation disk should auto boot if not it is corrupt
Go into explore and find the CD drive with the disk in, double click on the drive and the contents should be displayed on the file listings
If not go into add and remove programs and unistall any other copies you may have made of the software
Unplug the printer before trying a fresh install and if you know how to do it change the boot sequence into asking for the CD/DVD as the first option.
Lastly try plugging the USB cable into the PC when Windows is fully loaded , it should try to find the software itself
Sep 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark x2600m installation problem
Chances are to make the printer scanner work correctly, you will have to add memory to your computer. I f you are so inclined, have a look inside of your computer and check for vacant memory slots, if you have one, pop out the existing me ory and take it into your preferred supplier to match it up. if you do not have a vacant slot, one again take out the memory and take it in and upgrade the mamory to larger chips.
Hope this is of some help.
Ed
May 19, 2009 | Office Equipment & Supplies
Need to download free software to install Lexmark X2600m printer
Hi ebonymhart,
Here is the site that has the specific drivers/software that you need for your printer:
http://driverscollection.com/?H=X2600&By=Lexmark
They have the drivers for Windows XP, Vista etc.
Hope that helps,
Take care,
Michael
Nov 16, 2008 | Office Equipment & Supplies
HP Deskjet F380 Drivers
I miss placed my Printer Software driver CD when shifting the house. I bought new computer and I want to install the printer into it can you please provide me with the driver
I AM NOT ABLE INSTALL HP DESKJET F 380 ALL-in-one Printer as i missed the driver CD
i want software
Jul 10, 2008 | HP DeskJet F380 All-In-One Printer
Lexmark C533DN InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
