Question about Bernina Bernette Deco 600
Just got my used Bernina deco 650 from the shop. Tension off
Just got my used Bernina deco 650 from the shop. It was making loud noise after stitch and showing that the needle was bent. Company said I needed new motor which was not the case. Technician found thread cutter binding so he reinstalled rotary hook and thread cutter. Now tension seems off. Bobbin thread is running out quickly and shows through embroidery. Does the top tension number need to be higher or lower? Or is it related to the thread cutter again?
    Champion:
  • Bernina Expert
  • 300 Answers
Pshawver is correct, I have 40 years experience working on sewing machines
Posted on Feb 16, 2013
    Problem Solver:
  • 10 Answers
The tensions are not calibrated properly. To get by, or if you do not want to take it back to the shop, just lower the upper tension a little at a time until it looks ok.
I have 25 years experience working on sewing machines
Posted on Jun 30, 2009
Is it possible to get a bigger hoop size for the Bernina Bernette Deco 600?
here is a link for part for the machine, if the part you need is not on the link, you'll have to contact bernina website or a bernina dealer Bernina DECO 600 Parts
Mar 13, 2014 | Bernina Bernette Deco 600
Sews 1/4" and then sews in place
1) remove upper and bottom threads. Try sew without threads.
Is fabric transported corectly?
NO:
- Drop feed dog button is OFF
- Dust under stitch plate
- Transporter malfunction (must be taken for a service to the BERNINA dealer)
YES:
- Upper or bottom thread jammed
- The upper thread tension is too tight.
- Wrong needle used (probably small ...)
Nov 20, 2013 | Bernina Bernette Deco 600
Fix timing on the benina deco 650
Bring it to a Brother sewing machine repair shop, Brother made that machine, and sold to to Bernina, the servicing and especially the parts will be much cheaper at Brother. Bernina simply doubles the Brother price and sells it to you.
Oct 25, 2012 | Bernina Bernette Deco 600
I have a deco 600...the top thread is pulling thru to the bottom and making a mess..it seems as if the bobbin thread s not picking up. Could this be a timing issue? Can I fix this myself
sounds more like top tension device is faulting, can you clean between the tension discs? if you can get to them turn tension to zero and floss between discs with selvage edge of clean cotton fabric scrap. thread dye particles and lint will build up in there. timing off usually presents as the stitches not being made at all. always raise presser foot when threading up too. if top tension looks like it is not working correctly consider getting a service and clean done, should be done at least biannually.
Jun 07, 2011 | Bernina Bernette Deco 600
Bernina Deco 650. won't stitch
You need to take the machine to a Bernina dealer for service. It may just need the timing adjusted, or there could be something else that needs to be done.
Apr 19, 2010 | Bernina Bernette Deco 600
Bernette Deco 600 makes loud noise after stitching
hi! there,
open needle plate if the shuttle race and the bobbins has been pull out that making noise,or accumulation of thread under bobbins, if nothing there, run machine and check if shuttle race and bobbins are moving,also with the needle if not,there are opening at the bottom of machine try to open if some gears are broken,or belt is slip.
if broken gears there a lot of parts before you can pull out gear, beside the timing order you cannot put back.this should be done by technician expert
in sewing machine.take this to service center.
cheers have a nice day just rate me.
Apr 09, 2009 | Bernina Bernette Deco 600
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
I have s Bernina deco 650 embrodiery machine and the stitches won't catch. I had this machine serviced before I moved from SD to an eastern state. It was sewing fine and just started making a noise like it...
Your timing is out in the bobbin area this will have to be reset, maybe the last time that you used it you had a cotton jam, and it was pulled out of alignment.
Aug 07, 2008 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
513 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
