Question about iRiver T30 MP3 Player
PC does not see t30
Hi everebody!
My t30 does not connect to any pc(windows,linux), no more files transfer, the firmware is broken :-((
hardware is ok, all functions mic/rec/menu/settings work
probably i need to do low-level flashing, then i need a dos or xp driver for t30
where to get it?
any ideas /any fellow-sufferers???
  • 1 more comment
  • kizziykan Nov 28, 2007
    same thing here....i dont know what to do
  • shakes81 Dec 05, 2007
    i have exactly the same problem here
  • NASIQUE Jan 02, 2008
    Hi folks!
    i tried aleady several os windows, linux - usless
    i need driver, wich probably owns only manufactor something like
    low level formating solution for DOS,
    does anybody know is there any DOS driverĀ forĀ this device?
    can enyone tell, whether t60 is better as t30
    or still the same, i mean quality of sound
    links with test results etc.would be appreciated.
SAME PROBLEM...going to return it tomorow..the problem is that it works only with US and EU win seem that i dont have windows for that market.. check your OS.......
Posted on Jan 02, 2008
How i transfer data from window to linux
Depending on your linux distrobution, you will need to check the /etc/samba or /etc/smb configuration file, within that file there will be a place to set your windowsfile sharing password. then you will be able to transfer data across the local network between your linux / windows machine again..
however, if you've actually changed the password for the linux user account that enabled the samba file sharing, you will need to either remember that password, or set a new one from the root account byt typing the following command in a terminal / bash / shell session:
Task: Set or change user password Type passwd command as follows>
$ passwd <user>
Output: Changing password for <user>
Enter new password:
Retype new password:
passwd: password updated successfully
NOTE: when typing the password, you may not see the password you are typing..
You need to replace <user> with the username you are changing the password for.
May 25, 2009 | Dell Dimension 1100 PC Desktop
Hp 1000 notebook wlan
Yes you will need driver / software for it, what wireless adapter you got?
Oct 04, 2008 | HP Pavilion dv1000 Notebook
My mp3player isn't recognized by my computer.
OK, this problem was driving me almost to tears with frustration but have managed to bodge-solve it so hope this helps!
Right click My computer and select Properties.
Click on Hardware tab.
Click on Device Manager.
Hopefully there is a yellow question mark symbol against Iriver T30 listed under other devices or portable devices or something.
Right click this then select Update Driver.
Tell it that you are going to manually update the driver yourself.
Eventually you will have to select what type of device it is - select portable device.
Now click on MTP device and click next to install the driver.
Hopefully now it is recognised by XP in My Computer....
Good luck
May 07, 2009 | iRiver T30 MP3 Player
I cannot get music to load on to my coby mp3 player
Downloading/Uploading files
1. Connect the player to PC.
2. Open WindowExplorer on PC.
3. Select the file to save and drag-and drop it into the
removable disc icon. You can also transfer file fromthe
player to your PC.
Do not remove the player while it's transferring files.
It might currupt or damage the firmware and or files
on the player. If the player is accidently removed
while transferring and does not work properly,
remove battery for 3 seconds and replace it.
Disconnecting the Player
After completing the file t ransfer, you must disconnect the
player as following direction:
Double-click on the green arrow in the taskbar on the
bottomright of the window.
When the [Stop a Hardware] message appears, press the
[OK] button and disconnect the USB port.
Dec 02, 2008 | Coby MP-C827 MP3 Player
It can also be caused by transferring DRM (Digital Rights Management) encoded media files via the drag and drop method. It is recommended that you use the drag and drop method to transfer audio files that are not encoded with DRM. If in doubt, use either Creative MediaSource Organizer or Windows Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and transfer the content again. You can also download and install the latest firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows Explorer, and locate the Removable Drive listing and right click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After the formatting is complete, make sure that you stop your player before disconnecting it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of your player from below.
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Jan 21, 2008 | Creative Labs MuVo Micro N200 MP3 Player
Creative zen micro doesn't show so I can transfer
1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
2. Uninstall Windows Media Player 11 and Windows Media Player 11 runtime. This will rollback the pc to an earlier version of WMP.
3. Download the latest version of the zen driver from this location:
4. Make sure the zen is not connected to the pc and install run the exe file to install the software on your pc. at some point, the install will tell you that the unit is not connected. Connect the unit to proceed. it will also notify you that you are replacing an existing software, or something to that effect. I accepted or said OK to this popup. Once the firmware is installed, my started to work fine. You can now reinstall WMP from microsoft website. Hope this works for you.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Jan 18, 2008 | Creative Labs Zen Micro MP3 Player
Cannot transfer files
go to
download the updater. unzip the file and run the installation program. after you have install the iriver firmware updater, run the program. it will automatically detect what you need. follow the instructions. if the updater stops at 50% don't worry. wait bout a min or 2 then unplug your T30 and it will update by itself
Dec 07, 2007 | iRiver T30 MP3 Player
File system error
hi! all,
when i connect my muvo n200 256MB, it show h: is not accesible. The request could not be performed because of an I/O device. Please help what can be done. please reply
Aug 01, 2007 | Creative Labs MuVo Micro N200 MP3 Player
iRiver T30 MP3 Player Logo
140 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
