Question about JVC HM-DH30000U DVHS VCR
I have a picture on my recordings but no sound. Even tapes I've watched before now don't appear to have any sound at all.
  • 630 Answers
Check that the SCART cable is securely in at both ends.
Posted on Jun 29, 2009
My Magnavox VCR/DVD combo groans when I set the timer recording. It doesn't make the noise when I turn it off.
I hate to sound elitist or negative, but VCR is over, much in the same way that cassette tapes are over. It is even getting hard to find DVD recorders which stand alone. Additionally, I would urge you to record all of your home movies and significant recordings to DVD while you can. VCR tapes degrade pretty rapidly compared to DVD. And now, even DVD is on the way out. Get up to speed. You'll be glad you did!
Jan 18, 2018 | Magnavox DV225MG9 DVD Player VCR
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
The picture just stopped working, as did the
I had a problem like this with another mini-DV camera (Canon GL1) and I took care of the problem.My first thought is to use a head cleaner tape (dry head). It sounds like you have a dirty video head. DON'T try to use anything else, don't stick anything into the head or tape area. No liquids like alcohol with a q-tip, din't stick you finger in there (oils) and NO METAL. You don't want to scratch the head, even a q-tip, Kleenex, plastic, wood, cotton, t-shirt will scratch the head (and lenses). If this doesn't work, you may need to have it cleaned in a shop. Good Luck!
Dec 28, 2009 | JVC GR-D870 Mini DV Camcorder
My panasonic nv-gs15
The symptom appears to be video head clogging. I would first try to use head cleaning tape. (use new one). Run the cleaning tape for about 10 seconds but not more and see if it resolve the problem. If not, camcorder need a tracking adjustment by a technician. Good Luck. James. For further assistance, go to www.camerarepairjapan.com
Mar 26, 2009 | Panasonic NV-GS15 Mini DV Digital...
F11 error message in ag dv2700 during play.
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
Mar 09, 2009 | Panasonic AG-DV2700 Mini DV VCR
Toshiba D-VR650 can't tape says canot record protected image
THERE IS A TAB ON THE VCR TAPES IT CAN BE BROKEN OUT TO KEEP PEOPLE FROM TAPING OVER YOUR PERSONAL TAPES.LOOK AND SEE IF THIS IS NOT BROKEN OUT. IF IT IS PUT SOME TAPE OVER IT AND IT WILL RECORD ON THAT TAPE AGAIN.
Feb 10, 2009 | Toshiba D-VR650
Tunner? Picture whites out
Is this when you are watching a DVD, or Tape, or when watching TV using the Combo's tuner? The effect you describe is caused by the video signal losing its DC level.
Hope Ya Fix it.
Jan 08, 2008 | JVC DR-MV1SUS DVD Recorder / VCR Combo
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
JVC HM-DH30000U DVHS VCR Logo
71 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
