Question about Toshiba Satellite A135-S4527 Notebook
My screen is blank. The computer appears to be
My screen is blank. The computer appears to be running but I cant see any video. I tried connecting to an outside monitor, and the the toshiba icon came up on the screen but once windows loaded I got nothing.
  • Joshua Escasinas
    Joshua Escasinas May 11, 2010
    have you tried reformatting?...
  • 99 Answers
Actually its set to start on multiple monitors if you plug it in and it shuts off after windows loads fress and hold the fn button and the f5 button after the screen shuts off. you should get a picture on the external monitor your screen its self is probably broken. any more questions you can email me at meanness628@aim.com
Posted on Jun 30, 2009
    Sergeant:
  • 145 Answers
I think u got memory problem, it didnt load because of broken, sometimes it affected by crashed batery....u can try to disable memory shadow from the bios, and try enter windows again...
other option is, unplug your battery
Posted on Jun 29, 2009
  • ari yoso
    ari yoso Jun 29, 2009
  • 630 Answers
Sounds like a driver problem. Hold F8 when it's booting and try Safe Mode
The devices cant connect to the server it only displays a blank screen after connecting please help
check the cable connections. try a different monitor, check the mode on the monitor analog,digital, s video
Jul 11, 2015 | NComputing L300 Terminal Computer PC...
Acer Aspire One has a blank screen, but is logging on and able to function. Can click and hear sounds when I do and when it starts up, as if it were running normally, but the screen is blank so I can't...
Connect an external monitor and use the computer to check the screen settings. If changing the settings doesn't fix the problem, the screen or the lamp driver needs to be replaced. I have seen many Aspire One with screen problems, appears to be quite common.
Good luck
Nov 23, 2010 | Acer Aspire One PC Notebook
No video output from my computer.
Are you using an ON-board graphics adapter or a separate VIDEO CARD? Some motherboards lets you set the video output to "DISABLE ONBOARD GRAPHICS" if you have installed a video card (BIOS). You may have plugged the monitor cable to the onboard D-sub connection instead of using the Video Card D-sub connector.
Normally a flashing green power light means the input it receives from the video output is too much. You may have set the resolution too high or the bit depth too high. Consult the monitor manual on the rates it can handle. To be safe, try starting the computer on safe mode just to check if it is indeed the problem. If it boots properly and you can see your desktop, then there's a chance that the setting was too much for the monitor to handle.
Hope this gives you an idea.
Mar 15, 2009 | SAMTRON 94B 19 inch LCD Monitor
When I CONNECT MY CPU TO MY 42 PLASMA SCREEN
hi im josh in cebu phils .may i help you? Friend if the problem is when you connect the plasma screen it appears a seconds then blank. The problem is the video card of your pc output .it cannot supports your plasma screen. you need to use higher bit of video card for better output. good luck .
Feb 23, 2009 | ASUS P5P800-MX Motherboard
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Screen goes blank
Screen goes blank if your CPU have some problem, like lost connection or there some hardware cant detect your system. Sometimes the video cards, it will appear blank if it is overheat.
Jun 07, 2008 | Computers & Internet
Blank lcd on presario v3164au
r u able to log in safe mode.if yes uninstall the display adapter,if you cant then better send it for servicing
Apr 11, 2008 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
177 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
