Question about Toshiba Satellite A135-S4527 Notebook
When i turn on my laptop it stops on the screen with toshiba and leading innovation when i hit f12 it is not responding please help
  • Toshiba Master
  • 1,165 Answers
Hardrive failure.
Posted on Jun 29, 2009
When connected to ac adaptor it will turn on and toshiba leading innovation appear, but after that no program will displayed, but when i disconnected to the ac adaptor the programs runs normally. the
This is strange.
I think your ac adapter power cord is bad. Get another one from ebay at: http://www.ebay.com
Just put in your computer's make and model, not the model of the battery in the ebay search.
For example: Toshiba Satellite Pro L300 AC Adapter
It might be your lcd screen's inverter, but it's strange. Anyway test the inverter by plugging in the ac adapter and when the screen goes blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 20, 2012 | Toshiba Satellite Pro L300 Notebook
My laptop successfully power-on and display logo of Toshiba and stop with instruction of to press F12. But i when i press F12 it didn't respond, it just stuck there. please advise what is the problem?
If it's not booting to an operating system then more than likely it's looking for the hard drive and getting no response from it. When you see the Toshiba splash screen, hit the Esc key, then wait a minute or two, and it should beep and then ask you to hit F1 to enter Setup. Once you get into Setup if it says "not present" or "not used" in Fixed Disk Drive, then in all likelihood the hard drive has expired (died). This laptop uses 2.5" 9mm ATA / IDE drives that's pretty easy to replace - the hard drive compartment is at the bottom right next to the battery compartment. That'd be my best guess.
Aug 28, 2011 | Toshiba Portege 4000 Notebook
My laptop will not turn on when I press the power button. There is a screen that says toshiba leading innovations with the options of pressing f-2 or f12 for setup or boot selection menus but then the...
AFTER YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Computers & Internet
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
I have a toshiba laptop a3056872...on a friends pc now....when i go to turn it on..all the lights come on....the page tthat says toshiba innovation....hit f2 or f12....it doesnt go any further i have a...
1. Remove the battery & switch on the PC in AC mode.
2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
4. If still no display, connect an external monitor, check if display is comming.
5. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | Computers & Internet
When I turn the laptop on (L350) the screen starts with the "Toshiba leading innovation" page then is blank- dark grey. It does not respond to any keys including F2/F12
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Feb 07, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Does Not Turn On
First thing you're gonna want to try is reseating the memory.
Second, see if you can get into the bios by pressing F2, F10, DEL key it depends see if you see something on the screen, sometimes pressing ESC does it. It all depends.
Try that first and let me know what happens.
May 13, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
384 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
