Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have a 57'Sony big screen projection t.v. my problem is it comes on then the screen turns bright red then it just clicks itself off and the little red light keeps flashing on the time/standby feature.model #KP-57WS500 can anybody help me
techman
  • 3130 Answers
SOURCE: Problem starting a plasma
When it looks like its going to start up and it dosent then its an indication that one of the sweeps didnt start up. When you hit the power switch, the power supply sends an ok signal to start up the horizontal and vertical oscillators. When these start up they go to there respective drive circuits and then the vertical will send a signal to the power supply to keep on going so then the horizontal circuit starts up and sends an ok signal to keep going so then the set comes ob,\. If one of the two doesent start up and stay running then the power supply shuts down. To troublwe shoot these sets you need a service manualo and a good multmeter and a scope wouldnt hurt slso. This set has no user servicable parts inside of her so you need to take the set to a pro to assist you in the repair. Good Luck
Posted on Jun 01, 2006
SOURCE: projection picture problem
I had the same problem for about 3 - 4 months, one day it just stop working, not even that shrinked image. I called a service center recommended by the manufacturer and they took the TV with them. They told me the TV was damaged by lightning. I have my doubts but curious thing is that at the same time I also had problems with a smaller TV. After two months they brought it back. I paid 843 USD and it is working good. They replaced the main board, signal board and power supply. A total of 579.95 USD just in parts. This repair was too expensive considering I initially paid 1800 USD for the TV back in 2000. Next time I just going to replace the thing.
Posted on Sep 02, 2007
  • 50 Answers
SOURCE: Clicking sound!
Is this a dlp?
Posted on Feb 16, 2008
SOURCE: TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Posted on Apr 22, 2008
  • 3 Answers
SOURCE: I HAVE A PHILLIPS MODEL
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Posted on Dec 11, 2008
57 projection on light flashes but no picture
Look to see when it tries to come on if it flashed bright red, green or blue. This set listed is prone to bad tubes and if acting up will come up and screen may flash--also if not coming on count the blinks on the red light--a specific number of blinks like 6 or 8 is a error code.
Jun 15, 2012 | Sony Grand WEGA KDP-57WS550 57" Rear...
How do fix my 5 inch sony the light flashes 8 times
Prior to this were you getting a bright red, green, or blue screen with trace lines?
Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Kp-57hw40 screen goes bright red or green then powers off
http://esupport.sony.com/perl/news-item.pl?news_id=24
heres a recall of sony hope it helps.
Dec 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Sony big screen
is the pic bright red or dim with no video and small faint red lines??? if the picture is there then it sounds like the red screen on the High voltage block may be turned up a bit to high. Was somebody tring to focus the pic latly>> need more info please>
May 05, 2006 | Sony KP-57HW40 57" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
172 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
