Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
Same thing for me.
I think I broke the choke stop outside the carberator. I tried to bend it so it will stop earlier preventing engine to stall everytime. Where can I get a new carberator?
  • 1,165 Answers
Http://www.petessmallengine.com/
Posted on Jun 29, 2009
2002 izuzu rodeo 4x4 stopped runing while driving and now wont start and sounds bad when i try to start it.
all engines can stall
with modern engines, the PCM does everything in its power, to prevent stalls .
the top cause is bad spark plugs or bad spark.
if then engine make odd sounds,?
all engines the run too slow shake and make odd sounds.
if the sound is metallic, (think of Micky mouse with tiny hammer hitting a tin bucket) that be bad sound.
no engine stated,but if the sounds are bad, id not ever try to start it. or bend valves in the head. (4cylinder)
if you ignored the cam belt, and not service it (new one)
at the proper time , the engine either stalls, no damage
or with 4cyl yes, damage.
both the 2.2L gas and 2.2l diesel engines are interference engines.
if you told me what engine you have, I can give 10x better advice.
do not run the 2.2L if the engine sounds BAD.
or you make it worse.
Jan 09, 2017 | Isuzu Rodeo Cars & Trucks
Car stall when stop an AC on
have pressure relief valve checked on low side of a/c pipe
Jul 24, 2016 | AC Cars & Trucks
I have a 2006 Suzuki Reno and everytime i turn on the AC my car shuts down and my steering wheel locks up, all my lights come on and on the freeway it shakes like crazy. Please help!!! Thanks :)
That is called a stalled engine , causes p/s to get harder to turn, key "on" , but never lockup...ever.
steering lockup is something else and vastly dangerous moving..
stalls have over 50 causes. ill not list all 50
1:never ever tuned up?, the 60k mile service skipped?
spark parts and filters.... bla bla.
2: ISC bad, stuck , clean it.yet>?
3: EGR stuck open rpm is already too low and A/C pushes it over the cliff... (tunes check this)
4: A/c compressor seizing? (get it checked)
5: lean fuel mixture. (lots of causes ask if you have tools how to find that, i bet NOT)
6: spark bad, not tuneup relate, say coil pack bad.
7: ever use a scan tool and see if there are DTC errors at the stall say, P03xx errors??
my guess is you dont know how to scan if true then why not get car serviced, and not ask for help to do things you can't do. or are unwilling to do or buy the tools needed.?
lots more, if list all parts that can weaken and engine cause it to not have enough power to run AC.
does engine have full power in demand by you. up hills? (bam,.shoe falls off other foot)
answered now in pure physics.!
1: a weak engine, for 50 reasons. includes ISC bad.
2: A/C compressor seizing.
Apr 30, 2015 | 2006 Suzuki Reno
99 FXDWG, Choke cable broke, bike stalled then wouldn't start. I fixed the choke cable but bike still won't start. Any ideas?
"Crank" and "turn over" mean exactly the same thing. I think you mean it won't "fire". How did your choke cable break on the highway? You shouldn't have been pulling (closing) the choke at that point - does that ride have other issues?
It might be flooded now - try letting it sit for several hours, then try starting with the throttle WIDE OPEN and no choke - that helps clear extra gas out of the cylinders.
You might also need to pull the spark plugs and dry them out thoroughly.
Aug 13, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
06 honda element dies in am replaced iacv & still does it???
hot engine or cold or both, just a clue here.
wow gue$$sing is expen$ive.
is the CEL lamp glowing ever running,, YES?< then scan it.
ok so it stalls.
after the skipped 60k mile tuneup is done
if it still stalls.
so you use the right foot action fast acting at stall...?????
and you can prevent the stall easy.
1: very easy, iSC stuck closed or throttle idle detection is bad.
2: harder to stop stall but can , EGR leaks, main EGR valve.
3: impossible. this is gross spark failure ,or loss fuel or flooding
see how far you get on my list. and post back.
first ,now how the EFI works not guessing
it tries all the time to prevent stalls if it cant prevent it, it does stall.
rule2, the ECU controls idle speeds at all times the ISC is the slave to that..... so if the ECU open the valve and the stall gets worse.
its not the ISC/ECU fault. its fueling or spark.
a lean engine stalls. if lean enough ,no ISC can stop that.
a misfiring engine stalls, too.
a tech, dont attach the ISC< no he does not
he looks at spark an fuel rates. using , a scan tool.
The ISC can not cover the bad tracks of bad fueling and spark
nor a stuck open EGR.
THE ISC is dead if the TPS is set wrong, and the ECU thinks wrongly
that you are not at idle. so the ECU cuts idle controls
I use my scan tool to watch the, for error,s DTCS,. and pending errors
and watch for closed loop at idle. hot.
if it is in close loop at idle and it stalls then the ISC is failing
if rigth foot can save it easy.
id bet the fueling and spark are bad or TPS not closed, signalling close or the EGR is stuck wide open'
btw., if eCU drop s to limphome mod (scan it) it will infact drop all ISC
idle controls..
we look for the true cause, do tests, then replace parts
never the reverse or go broke fast.
Feb 02, 2014 | Honda Element Cars & Trucks
I need to rev the throttle to prevent the engine from stalling.
Try checking these two things: idle adjustment (usually milled screw on the carburettor) or there could be a problem with the governor - this is usually a plate that is driven by the airflow from the cooling fan, check that this moves freely (usually a shaft from the cooling fan on to the carburettor butterfly valve), if this is not free, then the engine will only run on idle, will not reach running speed, garden debris can cause it to jam...
Nov 06, 2013 | Ardisam Earthquake Mini Cultivator 43cc...
Runs only with full choke
clean carb,then adjust, do not use low end gas,(to many contaminates.use carberator cleaner in gas(read instructions, small tank)
Aug 30, 2012 | 1985 Honda VT 500 C Shadow
1987 Magna VF 700 Bike stalls when its cold outside
just a common thing in cold weather, sometimes you have to ride about 5 miles with choke half out, till the engine warms up. try draining your carbys or cleaning them out, sounds like ti could be running abit lean and not getting enough fuel
May 23, 2010 | 1987 Honda VF 750 C Super magna
My 1993 Honda TRX 90 Fourtrax has issues...
You will have to clean the carburator, blow the jets with compressed air,check the float level too and reset.
Good luck.
Jul 19, 2009 | 2003 Honda CRF 150 F
1987 4x2 idling really fast when cold and stalling
Its idiling fast cause ur choke is on it mabey broke and flooding the engine check your choke valve
Nov 22, 2008 | 1987 Toyota Pickup
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
124 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
