Question about HP Officejet Pro L7680 All-In-One Printer
When we receive a fax, it only prints the first few lines of each
HP l 7680
  • 94 Answers
Could not understand your question, could you please repeate ?
Posted on Jun 29, 2009
Hp 7680 does not receive fax-test fax to hp works
Fax tone in different countries differ. Check your "FAX tone" detection setting. Otherwise turn off fax tone detection - pick up every call.
Oct 30, 2013 | HP Office Equipment & Supplies
I can't receive faxes on my hp 7680 printer
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 18, 2012 | HP Officejet Pro L7680 All-In-One Printer
HP OFFICEJET 6500 SAYS NO COMPUTER CONNECTED WHEN RECEIVING A FAX, BUT PRINTS FROM THE SAME COMPUTER
to receive fax, you must connect the fax line to the printer. All-in-one printer can received fax without computer.
Sep 26, 2011 | HP Officejet 6500 Wireless All-in-One...
We have the L 7680. Last week we changed from ATT dsl line with filter to ATT Uverse. They installed. With the change, our fax stopped working in/out. It reads as No Answer from outbound attempts and...
The Uverse service appears to be all digital - so any voice/phone channels are going to be VOIP....not real analog lines as you had before. So, you need to connect the HP fax to a phone line service. Did ATT provide you a phone number? (or perhaps 2 phone numbers) Then the fax should be connected to that line. If you are unsure, then connect a phone to the provided line and listen for dial tone. If you are connecting a fax to a VOIP line then a good suggestion is to drop the fax speed to 9600....this will provide more reliable connections. Hope this helps
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can I print a list of faxes sent the past week on my HP 7680?
Sorry but NO.
You SHOULD be able to print off a list of the NUMBERS you dialled but not the actual fax which is actually sent as a PICTURE. This is gone forever.
For the numbers go into the memory of the machine and look for the list in SENT.
Feb 26, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
HP 7680 Fax paper will not go through
Have you checked that you can get a dial tone?
Can you recieve fax's?.
If no dial tone then check that you have the telephone cord plugged into the line jack on the back of the fax machine and not the tel or ext sockets.May be a telstra problem so plug another phone into the wall socket to see if you can dial out.
Also make sure that the fax is set to pulse dialing.
Oct 25, 2009 | HP Office Equipment & Supplies
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 7680 WILL NOT FAX
HI ,
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Thanks .
May 19, 2008 | HP Officejet Pro L7680 All-In-One Printer
How do i gwet the hp officejet pro 7680 to get two short rings
To change the answer ring pattern for distinctive ring via the control panel 1 Verify that the device is set to answer fax calls automatically. 2 Press Setup. 3 Press Advance Fax Setup, and then press Distinctive Ring. 4 Press the right arrow button to select an option, and then press OK. When the phone rings with the ring pattern assigned to your fax line, the device answers the call and receives the fax
Mar 13, 2008 | Office Equipment & Supplies
HP 7680 All for one printing question
I have been unable to enlarge anything on my officejet 7680 fax/copier/printer.I have hit the enlarge reduce button and tried all the options in the window but nothing happens.I must be doing something wrong.Can you assist me with this?
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
