Question about La Crosse Radio Controlled Atomic Clock
La Cross Atomic Clock from Costco is 1 hour behind
Our clock is working fine with the exception that it is one hour behind and it would not adjust to a new time. We changed the battery and still no results. We are in Toronto, ON, Canada.
2 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Posted on Mar 19, 2010
How do you set this clock after changing the batteries
There should be adjustment buttons somewhere on the device. The actual time is set automatically by the atomic standard signal.
Jul 28, 2017 | Home
Hands rotate endlessly onatomic clock wt 3143
If you have not talked to La Cross and if you continue to have the problem, most likely it may be a signal problem. I had a similar
problem with an earlier model and found that it only worked on
the west facing wall as the signal is coming from WWVB which is the NISTtime signal radio station near Fort Collins, Colorado. Get a fresh battery, reset the clock, put it in a west facing window and leave it overnight. If it doesn't work, contact La Cross as above post.
Dec 12, 2014 | La Crosse Radio Controlled Atomic Clock
HI I live in Hawaii we dont go by pacific time zone like California how do I set my clock WT-3122A
Aloha. Try asking your question here: Clocks Watches Questions . They helped me before with an antique clock problem. Good Luck.
Oct 04, 2014 | La Crosse Technology WT-3122A 12.5" Wood...
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
Atomic Clock Daylight Savings
Your clock may need to receive a signal indicating the time change. You can try moving it to another room, or outside to see if it reads the signal. Mine didn't, so I removed the battery and reset the clock. It wasn't obvious how to do that and I didn't save the owner's manual but upon close inspection there was a tiny black button (that looks like where you would lift a cover for a battery) and pressing it allowed me to adjust to the correct time. It is a "Sharp" bought at Target a couple of years ago.
Mar 10, 2009 | La Crosse Technology WT-2171-UCS Digital...
Time is behind 4 hours, wont start with new battery
I inserted new batteries, second hand would not move at all. 1 hour later I came back and clock was running with the correct time.
Jan 29, 2009 | La Crosse Radio Controlled Atomic Clock
Skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone
and select your zone then press set button.
to normal mode and adjust the current time.
Mar 08, 2008 | SkyScan 86709 Atomic Wall Clock
Radio controlled clock won't set
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Feb 15, 2008 | La Crosse Radio Controlled Atomic Clock
La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
La Crosse Radio Controlled Atomic Clock Logo
226 people viewed this question
Top La Crosse Home Experts
David Burbee
David Burbee
Are you a La Crosse Home Expert? Answer questions, earn points and help others
