Question about Sony Playstation 3 (PS3) Console
I was going to constantly back and forth to my friends house and i brought my ps3. in my home i had the basic settings. at his house i had the hdmi. now niether works. please help me
  • 101 Answers
Set up your ps3, go to turn it on but keep your finger pressed down on the on button for a couple of seconds until you hear it beep twice.
This should reset the input and hopefully solve your problem, if not turn it off and try again this time hold for 5 secs this should do a full reset of the ps3
good luck
Posted on Jun 29, 2009
My ps3 was recently connected to a hdmi cord at my friends house now im back home nd i plug the av cords in and nothing is coming up its still connected to the hdmi
Hello. Sounds like you need to adjust the video output setting back to component. Go to settings, display settings, then video output setting. you may need to do this under an hdmi connection in order to see it. Once you change it to component then it will switch over to a standard AV connection.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
I took my PS3 to a friends and we used an HDMI cable to hook it to his tv and when he brought it back to my house and now it wont work, i use the red ywllow and white audio/video plugs. why wont my...
hey, when you used the HDMI cable at your friends place, the PS3 display got set to 1080p. to bring it back to standard definition (red, white, yellow wire), follow these steps.
turn off you TV and PS3
turn on your TV
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings.
Now you should be able to see your PS3 menu on the TV.
Happy to help :)
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
I brought my ps3 home from my office and it was working fine there but will only turn on and nothing will display on the tv. I use hdmi on the tv in the office and was trying to use the 3 prong at the...
You must go back to the origional place you used the HDMI last, and do all the setting up & hook up again, to get a picture, THEN set it to component, or AV, and THEN turn off shut down, Now it will work at the other place OK.
Feb 23, 2010 | Sony Playstation 3 (PS3) Console
HDMI cable vs non
I use this method to revert from HDMI 1080p to Composite 576p, without having to swap cables and change settings.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
I can not get ps3 to show on TV. It turns on, green light in front with blue light with disk in.
you might have it stuck on a different video output e.g HDMI or AV. i had the same problem when i took my ps3 to a friends house mine was stuck on HDMI from my tv and i put it on my friend's tv on AV and it didnt show up i thought my ps3 was broke but when i got it home i realised you have to change it from HDMI to AV through settings on the XMB on display settings. hope this helps
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
No main menu or video shows on tv
u need to set the display output back to standard av cables. search online and there should be steps on how to do this.
Aug 03, 2008 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
