Question about Dell 1125 All-In-One Laser Printer
Where are papertray release taps located in the "Dell Laser printer MFP1125" ? (in order to take the paper tray out for shipping.)
  • 35 Answers
For the upper paper lip, just lift it up (rotate upwards), and pull towards you to remove.
As for the lower paper tray, remove the cover (it should come off easily), and use a flat screwdriver to pry the two round light-grey colored tab on the inside inboard to release the drawer. It takes some fiddling around to get it loose, but it does come loose... Just be careful since those tabs are very brittle and can snap easily.
Best bet is to use the original box for safe transportation, that way you won't need to remove the tray...
Posted on Aug 05, 2009
I have a Canon MF6180dw and want to print a single envelope, how?
Simply place the envelop in Tray 1 making sure the paper guide are adjusted for the envelop and you should be fine.
Feb 06, 2014 | Canon MF6180DW - MFP - LASER PRINTER -...
Manual for dell mfp1125
Location of user guide in PDF format:
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-mfp1125_User%27s%20Guide_en-us.pdf
Mar 03, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
Xerox Phaser 6180 keeps saying load papertray with
Remove the paper tray and check the guides. Make sure they are lined up on the 8.5 X 11 marks. If it is lined up, try going into the menu of the printer and reset back to defaults.
Jul 21, 2011 | Xerox Phaser 6180N Laser Printer
Paper keeps jamming. we get a partially printed page,then jams about 2/3 of the way and we have to pull it out.
You can avoid most paper jams by correctly loadingpaper and other media in the printer. Tips on how to help prevent paper jams · Do not loadwrinkled, creased, or damp paper. · Make sure thepaper is not buckled in the tray. · Never mixpaper/media types within a single tray. · Flex, fan, andstraighten paper before you load it. · Do not exceed themaximum stack height. · Push all papertrays firmly into the printer after loading them. · Make sure theguides in the trays are positioned snugly against the paper. · Do not remove anypaper trays while a job is printing. Wait for a Load Paper light sequencebefore you remove the tray. See the 'Load Media' section on page 61 of theUser's Guide for more information. · Use onlyrecommended paper. Consult the CardStock & Label Guide on the Lexmark web site for more information aboutwhich paper provides optimum results for your printing environment. For additional assistance, please contact LexmarkTechnical Support.
May 31, 2011 | Lexmark E232 Laser Printer
Paper tray doesn't raise on my brothers hl5250dn printer. Says papertray empty
I have had the same exact problem; make absolutely sure that the exit chute is seating properly. With the exit chute open (as if to clear a paper jam) actuate the white spring loaded clips that hold the exit chute, mine were not traveling to their full extension and by moving them a few times this resolved and the exit chute was held more firmly and the rollers spin the right direction.
Jan 30, 2011 | Brother Lower Paper Tray Feeder / Tray for...
T640 gives 242.10 error no paper jam found does not happen all the time I open tray 2 , close and hit check works will happen from tray 2 only
Hi, most possible cause are worn rubbers tires in the papertray. You'll have to replace them. Partnumber is 40X0070. For now you can try to take the off and mount them inside out.
Good luck, Gerrit Jan
Jul 17, 2009 | Lexmark T640 Laser Printer
Dell laser printer MFP 1125 paper tray removal
I just did this 5 min ago. The tabs that hold it on the machine have cams that hold it in. just squeeze the tray lightly at the tabs and it slides right out.
May 31, 2009 | Dell 1125 All-In-One Laser Printer
Dell 968 Paper-out when it is not out
hi thanks for using fixya!
On this kind of error, might the sensor has been damaged, I suggest that you bring your printer for maintenance just to check clearly the error.
Regards!
If you need further assistance, let me know!
Mar 30, 2009 | HP Office Equipment & Supplies
Dell 1600N printer paper jam
More than likely you need a new pick up roller. It is located at the top of the tray area in the printer. You will see a black rubber roller with white nylon clips on both sides. You can confirm if it is the problem by removing and washing it with soap and water, then clipping it back in and running a few copies.
Mar 16, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1125 All-In-One Laser Printer Logo
198 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
