Question about Weber Q Grill
Why wont my old grill work with new propane tank
  • 32 Answers
Its not the regulator. the newer style plastic handle has an excess flow valve(spring operated shut off) just in case hose burns or breaks.the springs get weak.either replace the plastic handle or go with the old style left handed connection with no excess flow.also make sure u open valve on tank about 1/4 turn then open real slow.just so excess flow doesnt shut down gas flow...
Posted on Feb 20, 2015
  • 24 Answers
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Posted on Aug 04, 2014
radar001
  • 1051 Answers
SOURCE: Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
Posted on May 19, 2010
  • 15 Answers
SOURCE: New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Posted on Apr 16, 2010
  • 12 Answers
SOURCE: Weber Grill
check hose for leaks using sponge soapy water . check for pinched hose. possible plug inside hose.wire brush the flame area
Posted on Nov 09, 2008
burzerko
  • 254 Answers
SOURCE: low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Posted on Jul 20, 2008
Noggin
  • 944 Answers
SOURCE: gas grill
If you are sure that gas is coming out of the burner(s) at a roughly normal rate, then the only way it will not light is if you have a bad tank of propane. If you mean it lights but wont stay on, then the safety thermocouples (need to be hot to allow gas to flow) may be faulty - more likely somehow out of position - they can be gently bent back into place but not more than a couple of times. (the way to check if these are the problem is to make sure you are lighting the grill with the control knob in the "light" position - usually held in for a few seconds - this will bypass the thermocouples) If the problem is that the autostart feature is not working, then please post back with details and we can hopefully help identify the problem. Hope this helps - please post again with more info if not :)
Posted on Apr 21, 2007
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Grill isn't flowing propane when tank is on. No smell of propane and starter is clicking. Tested 3 tanks on grill and no luck. Tested same tanks on another grill and they work fine so it's the
it could be the reg or a blockage in the line or open the taps on the grill then close them reconnect gas tank open slowly then tis if there is gas to grill
Mar 16, 2012 | Barbeques Galore Turbo STS 3-Burner...
New propane tank. Burner will not light, no gas flow. This was a replacement grill from coleman because they couldn't get the regulator. Starting to get very disgusted with this product.
jcw - It sounds like the regulator is locked up from turning on the gas tank valve. Happens a lot with the new OPD Valves on the grill tanks.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Jun 18, 2011 | Coleman RoadTrip 9928-A50 Propane Grill
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
We just got a new propane tank and connected it and propane is not coming through
Disconnect and reconnect hand tight, open slowly, if this doesn't do the trick than tank valve is bad. Another thing that could be bad is your regulator, but I would start with tank first is grill worked before new tank.
Mar 21, 2010 | Thermos QuickSet 462836203 (LP) Grill
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
Apr 27, 2009 | Brinkmann Charmglow 810-7400-S Propane...
What would cause ice crystals to form on propane line
Bad hose, bad tank, or seals are gone. Recommenend buying a new tank and new hose. The Ice is from the propane freezing and the hissing noise is a leak from somewhere. Better to replace tank and hose and try again. You do not want to take a chance with propane
Apr 11, 2009 | Weber Genesis Silver B Grill
Weber Q Grill Logo
381 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
