Question about Cobra 29WXNWST (40 Channels) 2-Way Radio
I have a Cobra 28 wx nw st and the two ceramic capacitors had cracked on the antenna connections inside. These look to be for the weather part. But i am having a hard time identifying these to replace them. can some one tell me what they are. One is a 22j The other has a f on the top and a 3 the rest cracked apart.
4 pins
pin1 Ground (shield) and the red wire together
Pin 2 Audio white wire
Pin 3 Transmit blue wire
Pin 4 Receive Black receive
enjoy
CB Dave
Trenton Ontario
Posted on Jul 30, 2009
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Apr 10, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Twilli811@hotmail.com
check the SWR's on antenna. check microphone it has to work for the RX to be heard. cbshop
Sep 06, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Weather bleads Over on 21 LTD WX CLASSIC(*HELP*)
sounds like your wx receiver is being activated by a bad switch replace the switch to disable the wx when you dont want it to come thru
Jun 10, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Wx stations disappeared
They did not put all the plugs back in from the weather board. Part of what has to be fiddled with is underneath the weather board.
Open the bottom cover where the speaker is, on the right side you will see a board separate from the main board. Look for any plugs unplugged. Its probably one that got over looked.
If there are no plugs out, who ever you took it too may have turned something they should not have. most likely its a plug. Its probably the plug that runs the audio into the radio from the weather board. its working, the audio just isn't getting to the rest of the radio.
there are about 3 or 4 plugs from the weather board to the main board of the radio.
Nov 10, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Bad static
The Cobra 20 NW ST Wx is ( in my opion ) a very poor receiving radio. The ST is a bummer in all Cobra radios. The Static is apparent for the atmospheric conditioons and definally power lines and any high voltage will be picked up. When I get a customer with similiar complaints ( and there are a bunch ) I normally recommend that we turn the receive senativity down a bit. Sorry for this advise.
Ed
NC Electronic
Mills, Wyoming
Nov 20, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
96 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
