Windows file protectin - Computers & Internet
  • Tharinda
    Tharinda May 11, 2010
    Whats with it???
  • 3 Answers
You can hide the files & Mark Them systems files & it will be protected by the system
Right click on the file & Properties on the bottom select the system and apply and ok
Posted on Jun 29, 2009
Toxix headphones sometimes only one side works
You can remove the soft bit on the headphones protectin the ear, after that you can remove the plasic inner covering with a very small phillips head screwdriver, then you can see the wires inside and figure out how to fix the problem.
Mar 24, 2014 | ifrogz Earpollution Toxix Headphones
Check sump pressure? can you tell me what that means
Sump pressure is the back pressure created within the oil sump by pressure leaking past the piston rings. The pressure is usually very low due to the venting of the sump thru the oil sump vent (usually a tube or removable plug used for adding oil). If the vent was replaced with a plug, then pressure will be very high and cause oil leak. Higher sump pressure is also caused by adding too much oil into crank-case. If you are having other problems with compressor, post again. Good luck.
Dec 26, 2013 | Air Tools & Compressors
Trying to get sound on my panasonic tcl32c3 wHile connected to my laptop
Sound will not pass through a hdmi cable, you will need RCA cables that have a headphone jack on the end o run to the tv and computer. Copy protectin prohibits sound traveling using hdmi cables.
Jan 09, 2012 | Panasonic TCL32C3 TV
I cant sign in
hello
there are different security protectin in the computer
BIOS password Hard drive password User password for windows
BIOS password:
-you need to bring it to a local tech to have BIOS password removed
Hard drive password:
-there is no solution for that and if there is it is very expensive
User password for windows:
-you can follow the steps on the link below for different windows version.
"http://4sysops.com/archives/three-ways-to-reset-a-windows-vista-admin-password/"
Cheers.
Feb 24, 2011 | Dell Dimension 2400 PC Desktop
How can i remove the write protectin from my KODAK EASYSHARE Z1085 IS Digital Camera
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 25, 2010 | Kodak EASYSHARE Z1085 IS Digital Camera
Cooling fan module???
cooling fan module just refers to the fan, the motor and the shroud. There is no electronic module.
The fan has relays for protectin and the engine computer oerates it when it gets siganls from the engine coolant temp sensor, the A/C being on, etc.
what is your issue?
7d6a1ca.gif ------------------------------------------
Mar 15, 2009 | 1994 Ford Escort
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
Sep 18, 2008 | Audio Players & Recorders
How to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
Aug 29, 2008 | Nokia 3230
Power Protectin stays on
Sounds like you have blown your amplifier. There could be severqal causes for this happening. Take it to an electronics repair shop, but honestly you might just be better off replacing it altogether.
Jul 15, 2008 | JVC KS-AX704 Car Audio Amplifier
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
