Best Solution
posted on Jan 06, 2008
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Thanks J
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Ricoh FAX3800L Plain Paper Laser
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Repair Service
Find Fax Machine Repairman Near You:
