Question about Submersible Systems Submersible Sump Effluent Pump, Efl 33 1/3 Hp Effl
What oil is inside a 1/3 HP 1725 RPM effluent pump
I opened the case of a 1/3 HP 1725 RPM 115V 1 Phase effluent pump and lost some of the oil inside. I want to refill it. What kind of oil is it?
  • weidongwdh Jul 05, 2009
    I fingered out it is transformer oil
  • 832 Answers
You can refill it with capella oil. This is the same as the oil used in refrigerator compressors, and be acquired
from stores specializing in refrigeration and airconditioning. Send us an e-mail for further assistance.
Posted on Oct 29, 2009
  • rolando ingking Oct 29, 2009
Why will well pump lose its prime
George:
There is a packing or valve in the pump that is supposed to keep water in the pump. Either a packing (O ring) or a one-way valve has failed. If it is a "one way valve" there may be a piece of gunk holding the valve open allowing the prime to drain out of the pump.
May 19, 2015 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
Motor just hums when boat lift switch turned up or down
This is usually caused when the motor sits awhile w/o being used. Remove the rear cover with a flat blade screwdriver or 1/4" nut driver. using a flat screwdriver, spin the armature clockwise. this should fix it. If you cannot spin it, the motor should be replaced.
Feb 21, 2014 | A O Smith Motors AO Smith Pump Motors,...
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
I NEED TO REWIRE A DOERR LR24684 ELECTRIC MOTOR,ITS 1/2 HP, RPM 1725 115 volts to a metal lathe AND ON SWITCH IT'S WRITE- FOR IN DOWN IN CENTER STOP AND UP REV -I SEARCH TO CONNECT THIS...
Motor terminal box sometimes has a connection diagram inside the lid.
Basically a single phase induction motor has a run winding and a start winding and to reverse the direction the connections to one winding, usually the start winding, must be reversed and that is the function of the lathe switch.
Single phase motors are easily damaged and so if any doubt exists I strongly suggest you ask a motor specialist for assisstance.
Oct 09, 2017 | Cars & Trucks
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have a 1/3hp goulds pump not working i have changed the capacitor and the centrifugal switch but it still does not work; does not come on what must i look at next.
Check the continuity of the service wires. If they are good, check the resistance of the windings. You may have an open motor windings.
Jun 08, 2009 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Submersible Systems Submersible Sump Effluent Pump, Efl 33 1/3 Hp Effl Logo
269 people viewed this question
Top Submersible Systems Tools & Hardware - Others Experts
John Trevino
Are you a Submersible Systems Tool and Hardware - Other Expert? Answer questions, earn points and help others
