Question about Toro Lawn Mower With Toro Power Tools
I have a toro recycler lawn mower that was made in 2005 according to the sn. it wont start. we have tore it down to check everything but still nothing. It has spark. after pulling a few times we check the spark plug and it is wet with gas. so it is getting gas. we have the air filter off checked the carburator, seems fine. there is compression, I dont know how to check to see if it has enough but it seems as though there should be enough to at least start. we had it going for about 2 seconds once but nothing sense then. Im lost and dont know what to do next. It is a second hand mower so I am not even sure if all of the parts are there and on right but everything seems to be correct. I have checked the parts list. It is a tecumseh engine 6.5 hp. any help you can give I would be grateful for. thank you in advance.
No spark
Posted on Aug 26, 2009
    President:
  • 1,865 Answers
If you have spark and gas, it should start. The plug shouldn't be wet with gas, adjust the carbuerator fuel flow screw to reduce fuel to the engine. Use full choke to get it started
Posted on Jun 29, 2009
My toro super recycler bogs down while mowing. I have fresh gas, just changed the oil and filter. Any suggestions?
check and be sure the blades are sharp. if the blade gets a rounded edge it wont cut properly and will bog down trying to cut.
Aug 15, 2016 | Toro Power Lawn Mower
PTO wont engage how can you check
PDF]Owners Manual - Mowers Direct
www.mowersdirect.com/manuals/20382OM.pdfSuper Recycler® Lawn Mower. Model No. ... Whenever you need service, genuineToro parts, ... This manual identifies potential hazards and has safety.
You can download the above from google.
You can also check if there is a safety feature keeping the PTO from engaging.
Jul 17, 2015 | Toro Super Recycler Super Bagger Lawn...
Toro lawn mower troubleshooting
A dirty air filter is a common cause of this. Give it a look. Otherwise a replacement carb would be the route to take.
Aug 21, 2014 | Toro 20371 - 22In OHV Recycler High Wheel...
Why my toro recycler 22in personal pace lawn mower wont start ?
I recommend that you call the store and get service under the warrenty.
Aug 06, 2014 | Toro Garden
How to fix stuck pull cord of a 22 inch Toro Recycler lawn mower
Is the engine seized?. Try turning the blade and if it won't turn then you have a seized engine. If that is ok your recoil has a stuck part possibly something has broken off inside. If it's an older model try shooting WD40 inside the recoil as it could be rusty.
Jul 25, 2014 | Toro Garden
Will not start toro model143.026706
if it stopped running after hitting something with the blade check the key on the flywheel where it meets the crank
Jun 04, 2012 | Toro Power Lawn Mower
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
I have a 22in recycler lawn mover. the recoil
There is a safety brake on the handle that MUST be held down to start the engine. You must squeeze the safety agaist the handle to operate the mower. If not you will not be able to start the mower.
If your holding the safety mechanism and it is still locked then either the cable has become detached or... borken. Check to make sure the cable is connected to the safety mechanism. If it is and it still does not release then you should in all honesty contact Toro for the nearest warranty repair center.
Thanks for using FixYa.
Kelly
May 22, 2010 | Toro Lawn Mower With Toro Power Tools
Mower wont keep running
recycler toro 6hp. 10 years old,little usage. Starts then stops, have to keep priming. Can anyone help?
Jun 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
462 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
