Question about Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter
Internet connection lost
I installed Belkin bluetooth usb to use my bluetooth headset for Voip. This works ok but I cant load any internet pages. The wireless lan is connected but nothing loads. I get the message " cannot find server..." The only fix is uninstalling the belkin bluetooth. Help
5 Suggested Answers
SOURCE: all downlods stall
try disabling windows XP firewall...
Posted on May 20, 2007
  • 657 Answers
SOURCE: how to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem?
This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet.
something like this for an ADSL connection.
If you are on cable, you can either get a Router similar to the one above (but for cable)
or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities.
Posted on Oct 17, 2007
  • 67 Answers
SOURCE: lost disk and accidentally deleted wireless LAN networks and comp can
Download the driver here
Posted on Apr 12, 2009
  • 12 Answers
SOURCE: how to conect belkin wireless g usb net adapter to xbox 360
You can not use the Belkin Wireless G USB Adapter for the XBox 360. You must buy a USB Wifi adapter that supports the Xbox 360. (See Microsoft's USB WiFi Network Adapter)
Posted on May 26, 2009
  • 108 Answers
SOURCE: Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Posted on Jul 09, 2010
0 characters
1 Points
I have a problem with my NETGEAR WNA1100 Wireless-N 150 USB Adapter. I use it with my desktop PC and a Belkin 802.11g router placed in another room. As soon as I installed it, everything seemed to work...
Your Issue can be Solved by assigning DNS address on your Computer.
>First of all change the Security on the Belkin Router to WEP Mode.
--- Remove Preferred Networks From your Computer.
- Right Click on wireless Network Connection > Properties > Select Wireless Networks tab > Remove your network From Preferred Networks Box.
--- Associate with your wireless Network.
- Right Click on wireless Network Connection > View Available Wireless Networks > Select your network > Click connect
---> Check if you are able to go online.
--- If Not Try Assigning DNS Addresses For your Wireless Network
- Right Click on Wireless Network Connection > Properties > Under this connection uses the Following Items. > Double Click on Internet Protocol (TCP/IP).
- Select Use the Following DNS Server Addresses:
- Preferred DNS Server:
- Alternate DNS Server:
- Click OK & OK again
- Now Check if you are able to go online if still No go Check if you can go online on any other wireless Com or Device using the Belkin Router If Yes it Might Be an Issue with your Adapter or there Might Be an Antivirus Installed on your com Try Disabling it.
- If this doesn't work Please do get Back to us we will be happy to Help you out... :)
Mar 21, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
I have a belkin dongle but have lost the installation cd can i still connect to the internet without it
Yes, with help from a friend. This is what I did. On another computer with internet access working, go to
Find your exact product number and download the driver. Copy that download on to a USB memory stick. Take it out, plug that into your own computer and copy the driver program on to your computer. Then click on it and install it. It worked for me.
Aug 04, 2010 | Belkin (F5D7050) 802.11a/g/b Wireless...
Netgear WG111v3 USB adapter not connecting desktop to Belkin router. this notebook is working OK. The adapter has been working OK for about 3 weeks.
Try to download the newest driver from belkin that matches the version and model. Uninstall the old driver and install the new one. This should fix the issue. you will need a pc that is connected / working to the internet to get this done.
Jan 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Bluetooth USB Adapater, USB...
Bluetooth adaptor
here are your driver
Aug 13, 2008 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
my wireless connection says connectedbut won't display my web page (yahoo) in internet explorer but it use to work fine i have a belkin usb adapter wireless g networker
Apr 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin Dongle
You have to make sure first that the working pc is getting its internet connection from the BELKIN and not from the modem. To check that, right click the computer icon at the butoom right of your screen, click detail. ip address that is ok is in this form 192.168.xx.xx. If you are getting like 74.xx.xx.xx, that means that you are getting connection from the modem. THE MODEM ONLY GIVES ONE CONNECTION, MEANING THE ROUTER IS NOT FUNCTIONING CORRECTLY. After doing this you can give a follow up question.
Jan 19, 2008 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
My wg111 usb cant install
go to www.netgear.con and there you can find support page
Nov 20, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Lose wireless internet when printer is on.
the only thing that connects the printer to the internet fault is the fact that the printer and your belkin are both usb connected. If you are using a laptop then it could be a usb power problem and the motherboard is disconnecting the belkin adapter for some reason, the only one i can think of is a power problem. The same can apply to a desktop pc if there is a usb problem Firsly i assume you are using the belkin software to connect the usb adapter to the router, so on your taskbar on the right there is normally the little aerial type icon for the belkin adapter and a little pc screen showing the connection also, if you right click on one of theses icons you should get a line reading 'enable windows WZC', if you do get the option enable it and try using the windows connection software instead of the belkin as it may stop the disconnecting. Also ensure that when you installed the software to your printer your firewall and antivirus was dissabled as certain elements to the driver may not have been installed. Lasly, try using different usb ports if you have spare ones, with both the printer and the adapter as sometimes the chip on the board may be instructing the usb ports incorrectly as to which is required first, as windows asks for certain things eg input/output ports to be used first,in other words the IRQ (interupt request) may be causing the problem.
Jun 23, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter Logo
54 people viewed this question
Top Belkin Network & Wireless Adapters Experts
Martin Murray
 C. Dante
C. Dante
Are you a Belkin Network and Wireless Adapter Expert? Answer questions, earn points and help others
