Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Lower drawer on FP DD603 is very difficult to open/close
I took the drawer out, it looks like the lid is stuck in the down position. What do I do to fix it?
  • philtweedy Jun 30, 2009
    where do I see that flap valve
  • philtweedy Jul 04, 2009
    Lets start again, the bottom drawer works and does a full wash cycle, but the lid is stuck in the down position.
    What causes that fault and what s the remedy?
  • 749 Answers
Try to budge it out what do you mean stuck or clicked in position?
Posted on Jul 04, 2009
  • 854 Answers
Have your lid actuators checked.
Posted on Jun 30, 2009
  • 615 Answers
Try this.
There is a small flap valve (Part #525414P) that is about the size of a dime that isnt closing properly. Best bet is to replace the valves and try to get a DUAL air gap in its place where you can hook up each drawer to its own hose on the air gap.
Posted on Jun 29, 2009
Opened the drawer while it was running now the drawer will not close
Turn off the mains power and back on and see if there is any change.
The drawer lid is stuck in close position when you opened the drawer. Try to select another program on the panel and see if it clears the stuck lid.
Jan 18, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
On 2 door dishwasher model DD603 bottom draw is very hard to slide out or in. Can i remove draw to inspect and oil draw runners?
Hi- Most likely the lid is stuck in the down, or partially down position. This is usually caused by the lid actuators (motors) not returning the lid to its full up position and therefore the drawer top is dragging on the lid gasket. Replacing the lid actuators should resolve the problem. You'll need a F/P tech to change those for you. Hope this helps.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher lid stuck
the lids on dishdrawers are pulled down and sealed by lid activaters. there r two types, the screw type and the magnetic solonoid type. the reason your draw gets stuck is your lid activator is not releasing. there are 2 reasons for this 1st- 1 or both activators are faulty. 2nd the lid activator control board is faulty, which is located under the bottom drawer.pull the draw out and see if u can see if the lid is down on 1 side or both sides.please reply 4 more help.
May 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Model DD603 top drawer has no power and is difficult to open/shut....Help!!
No power to top drawer,.... sounds like the main pcb is shot.... and happened when the washer was in use, so the lid assembly is clamped down, you can still open it by pulling but has alot of resistance. easy to replace the PCB, but dear to buy it!...
Nov 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Fisher Paykel dishwasher Model # DD603. It is about 5 years old. My problem is that the top drawer is difficult to open Pulling it open it becomes easier once I get beyond a certain point. The...
Sounds like your lid actuators are not opening completely, they move the lid up and down. They are prone to failure, F/P has new actuators, German made, that can be installed and would probably solve the problem.
Jun 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Lid is stuck in "down" position on the right only.
k the only thing you can do is try starting then stopping each drawer to see if the lid will go back up if not it will even be a hard one for the serviceman. you can't swap the wires like you've done it will cause large problems like a jammed lid sorry.
Mar 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer stuck, gaskets rubbing, no power to controls
I see the question is posted in the DD603 section, so I am not sure if I am giving the proper advice. Are you sure this is a 602/601 series? A DD603 model has lid actuator motors, not the inflatable style seal. It sounds like the lid motors are in the DOWN position. Since the machine is "dead" what may have happened is the heater plate opened up (the heater plate is a dropping resistor inline with the machine's controller) when the machine was in use and that stopped everything dead.
Double-check your model number so we know what style of lid your machine has, The difference is huge between models.
Dec 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
109 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
