Hotpoint wma54 washing machine
Do you have any advice on how to change the bearings on my machine,any diagrams you have would be very useful. i have bearings for machine, but could do with hints and a diagram for attempting the repair. machine is only noisy during spin cycle. i'd like to see if the job is too difficult or something i can tackle myself. any help is greatly appreciated.
  • scobie 1 Nov 20, 2007
    I have the same problem but for an Aquarius WF240.Do i need a bearing extraction kit and does the drum need to come out?
  • deffo Mar 08, 2008
    Hi the bearings are very very noisy on my WMA74 can and if so how do i change them? a diagram would be usefull.many thanks
    Problem Solver:
  • 17 Answers
Being fairly mechanically adept - I tried this on my old Hotpoint WMA31 -- it took around 90 mins to get the drum out (virtually everything had to come out) and 1- mins to split it in two - then another 30 mins to knock the bearings out. I then ruined one new bearing trying to knock rather than pull it in and had to order a second set - then whatever I tried I could not get the drum fully back on the spindle (which was rather pitted) so ended up scrapping it !
As an aid to putting it back together I took 32 digital photos of different stages of getting the drum out so that is a measure of complexity...
Posted on Nov 25, 2007
Excessive noise - possibly dry bearing - particularly when on 'fast spin'.
Sound like your bearings ok, this machine does have a bearing kit available but you will need a professional to fit as it is not a simple fix and will take about 2 hours. Hope this helps.
Feb 28, 2011 | Hotpoint WMA54 Front Load Washer
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
How do I change the bearings ofr my hotpoint WMA54 washing machine?
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Dec 28, 2009 | Kenmore 43042 Front Load Washer
Where is the filter on the hotpoint wma54 washing machine?
Remove lower rear cover of washer, locate and remove large black hose fastened to drum, inside you will find the filter.
Please rate my solution.
Sep 22, 2009 | Hotpoint WMA54 Front Load Washer
Loud niose coming from my machine when spinning
  • Hi,
  • Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | Hotpoint WMA54 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Where is the filter on wma54 hotpoint washing machine
It is in the pipe which runs from drum to pump at the drum end.
Dec 15, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
sorry but not the job i would recommend to anyone not done or watched it done before its about the most difficult job to do on any machine, even though in my 20 years experience this is the easiest machine to do a drum bearing change on, most of the machine has to be stripped down, removing all the front panel / timer panel / door seal and drum front / drifting out the old bearings fitting the new ones and rebuilding the machine, not counting testing for and rectifying any damage the drum has done to the rest of the machine and surrounding parts, good luck if you attempt it, sorry
Sep 24, 2007 | Hotpoint WMA54 Front Load Washer
Washing Machines Logo
361 people viewed this question
Top Washing Machines Experts
