Question about Kodak EasyShare M863 Digital Camera
My M863 Kodak Easyshare camera turns right off.
I turn my camera on, it immediately turns itself off. I tried taking out the memory card and the battery, recharging the battery then turning it back on, it did nothing. I just got this camera for christmas of 2008 and it's now June of 2009. It worked marvelously when i went on vacation in April, but now, it's acting weird! HELP ME PLEASEEEE.
  • 1,165 Answers
Sounds like a power issue.maybe your batterysare no longer taking full charges
Posted on Jun 29, 2009
When I turn the camera on, I immediately get a blue screen with the message "Picture or video is protected." I can review what's on my memory card, but that's what I get when I want to...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 10, 2011 | Kodak EasyShare M863 Digital Camera
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
I have a kodak and it wil not let my upload my
If the camera finds it hard to read the SD card:
Memory card support for M863 is SD/MMC up to 8 Gigabyte.
If the camera is not transferring to the computer:
Here are some possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
Dec 09, 2009 | Kodak EasyShare M863 Digital Camera
M863 on turning on immediately closes down. Battery replaced and fully recharged-still problems persists.
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 21, 2009 | Kodak EasyShare C613 Digital Camera
Kodak EasyShare M863 Digital Camera -Blank screen
Hi Greg, Its not on the settings., Here the thing you need to Do
Turn Off the camera, remove the memory card then Turn On the camera and go to auto mode or smart scene., now if yu see black screen check the Lens is yur lens has cover or check if the Lens protracted. Now if the Lens has no cover and protracted thats good it means theres no problem on the lens., Now press Menu Button, If the options did not display it means LCD or screen is already defective. you can also press review button.,
Please call kodak Toll Free 1 800 235 6325 and have your camera repair., GudlucK!
Nov 05, 2009 | Cameras
My M863 Easyshare will not turn on. Battery has
For this problem try the following:
* Try removing the memory and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Sep 28, 2009 | Kodak EasyShare M863 Digital Camera
When i turn on the camera the lens comes out and retracts immediately
Here are the steps:
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
My camara wont turn on
Here are the steps:
Thanks.
Neerak21
Aug 27, 2009 | Kodak EasyShare M863 Digital Camera
Kodak M863 camera built-in flash stopped working. Camera's only 4 months old.
make sure the setting is on auto or something . check the knob at the top .
 if your internal memory is full, then you need to either put the pics on the computer or delete them . get a memory card so you have more room .
try taking out the battery for a little while or charging it .
if your niece deleted it all then it's gone , i'm sorry .
Mar 21, 2009 | Kodak EasyShare M863 Digital Camera
Kodak C533 turns on briefly but then turns right back off.
what type of battery are you using?try to use lithium or rechargeable batteries. Alkaline batteries can cause power issues. If you are using a memory card, try taking it off and turn camera on without the memory card. if is still does not power on, camera needs repair. you can set up repair for your Kodak camera at www.kodak.com/go/itg
Dec 05, 2008 | Kodak EasyShare C533 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
416 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
