Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Both lights go green for a moment when turned on but then panel flashes red 3 timesand there is no picture or sound. led on console returns to red
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
My Samsung TV won't turn on
Please describe the problem more accurately. Flashing red usually means 'stand-by' state, flashing blue/green - starting up. When (during that) do you have a sound? Are there any 'high voltage' sounds like soft screeching from the screen? Is it LCD or LED?
Mar 02, 2015 | Samsung Televison & Video
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    My sony grand wega 55 constantly will turn off picture and sound, green lamp light stays green and then after about 30 seconds the picture and sound return, it has the original bulb in the tv and is around...
    The LED light "LAMP" indication stay on or flashes in this problems?Yes,the projection lamp is the causes and problems.Change the projection lamp,should solved the problems.
    Jan 30, 2011 | Sony KDF-E55A20 55 in. LCD Television
    Flashing red light. Console fails to turn on.
    Follow all 6 videos and your PS3 will work again. and it wont cost you $150 with sonys Refurbish program
    Jul 25, 2010 | Sony Playstation 3 (PS3) Console
    When turned on green light flashes and no picture
    Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
    Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
    Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
    No Picture & No sound. Red LED, Green LED, Red LED.
    If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
    Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
    My xbox 360
    Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
    Aug 22, 2008 | Microsoft Xbox 360 Console
    Xbox360
    Sections 1, 3, and 4 are flashing red
    - General Hardware Failure
    Check the secondary Error Code per the instructions in the section below
    THINGS TO TRY
    1. Try restarting the console.
    2. If restarting the console does not resolve the behavior, follow these steps:
      • Turn the console off.
      • Unplug all the power and AV cables from the console.
      • Unplug the power cord from the wall socket.
      • Firmly reconnect all the cables.
      • Turn on the console.
    3. If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
    4. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
    Dec 17, 2007 | Microsoft Xbox 360 Console
    My xbox no show no picture
    3 Red Lights Flashing - is a general hardware failure
    • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
    • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
    • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
    Check here for more things to try
    Oct 30, 2007 | Microsoft Xbox 360 Console
    Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
    125 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
