Question about Epson LX-300 Matrix Printer
I receive this message in upper letside @ejl 1284.4 error when i print in excel and in ms word
3 Suggested Answers
SOURCE: PRINTING TWO EXTRA LINE ON
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
Posted on Oct 21, 2010
  • 48 Answers
SOURCE: Everytime I print there is
When a printer prints garbage, it usually indicates a faulty cable or a loose connection. Power OFF your printer and computer. Disconnect and reconnect the cable on the printer and computer. Once the cable has been reconnected, power the printer and computer back ON.
If you are still getting the error, take the cable and printer to another computer and it works fine, have your computer's port checked. If it still gives you garbage from another computer, have the printer taken in to be serviced.
Posted on Apr 05, 2011
Epson FX-890 prints 284.4 @EJL, what could be the problem
I already did answer a question like this today. Just google this, because this error is on the net, for many different computers and different OS'n. look what suits the best.
Jul 16, 2014 | Epson FX 890 Matrix Printer
Epson fx- 890 prints 284.4 @EJL what could be the problem
I googled this, and lots and lots of other users had the same problem. There are different solutions, depending on what computer the printer was connected.
Please google yourself, to see what solution fits the best.
My epson lq-300 printer prints @EJL 1284.4 @EJL at the top first why
@Nelstin: You are wonderful, perfect. I followed his instructions, deleting "@EJL 1284.4" and "@EJL" in two *. GPD files, the LQ-300 prints out normally. Thank you very much.
Sep 22, 2012 | Epson LQ 300+ Matrix Printer
Everytime I print there is un usual text that eppear in the upper left corner of my print out paper.. The error shows like this; @EJL 1284.4 @EJL
Apr 05, 2011 | Epson LX-300 Matrix Printer
PRINTING TWO EXTRA LINE ON @EJL 1284.4 @EJL ON EVERY FORM INVOICE AND CHECK EPSON LQ570+ RUNNING ON WINDOW 7
STEP 1:
STEP 2:
STEP 3:
STEP 4:
STEP 5:
Sep 01, 2010 | Epson LQ 580 Matrix Printer
Speed of excel is v slow
you are using microsoft office 2007 version. it need 1.5 GB ram. how much ram in your system?
Jan 26, 2009 | Compaq Presario 5000 PC Desktop
Unrequested characters and nos on top of printed matter
you can try with epson compatibel 9pin from the printer list
Jun 28, 2008 | Epson Dot Matrix LX-300+ II Printer
MS Excel
Can you please provide any additional information, including error messages generated by Excel? Without knowing the specific error message, your surest solution is to completely uninstall Microsoft Office by going to your Control Panel and double-clicking "Add/Remove Programs". Then, once Microsoft Office is uninstalled, reinstall it using the CD.
Nov 12, 2007 | Computers & Internet
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Printing a report
IS IT THROUGH EXCEL THAT YOU WANT TO TAKE THE PRINTOUT FROM? YES - OPEN A FRESH EXCEL SHEET. COPY AND PASTE EVERYTHING INTO THE NEW SHEET. TRY TAKING A PRINTOUT. YES - GOOD. NO - UNINSTALL AND REINSTALL MS OFFICE TRY ANOTHER PRINTOUT. YES - GOOD NO - CONTACT MICROSOFT VENDOR. NOTE : NO PRINTER DISQUALIFIES ANY MS DOCUMENT.THUS ERROR FROM MS VENDOR.
Sep 17, 2007 | HP Deskjet F340 All-In-One Printer
Epson LX-300 Matrix Printer Logo
726 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
