Question about Samsung Televison & Video
Lns 4095 dx/xaa tv loses signal and goes black,
Lns 4095 dx/xaa tv loses signal and goes black, sometimes it starts again showing the connection sometimes it shuts itself off. taking longer to come back on
techman
  • 3130 Answers
SOURCE: Sound cuts out periodically
Sounds like a poor or cold solder connection in the sound circuit. If your not a tech, this repair really should not cost an arm and a leg to repair , but maybe your first born??LOLOL No really if you have no solid state repair experience please seek out a local repair person to assist you in this repair.
Posted on Sep 24, 2006
Kazong
  • 152 Answers
SOURCE: assistant
check your sleep timer settings thats the most comman prob
Posted on Dec 18, 2007
SOURCE: Turns off by itself!!!
The flyback transformer are damaged .
Posted on May 28, 2008
SOURCE: Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Posted on Sep 22, 2009
pra0099
  • 153 Answers
SOURCE: Samsung TV , black screen
Check for the timer settings if possible reset to default......
Posted on Sep 28, 2009
Is there any way to buy a CPU for HLR5667WAX/XAA? How to replace it?
If you TV is 9 years old it is questionable whether further repairs are economically worthwhile.
Jun 05, 2014 | Samsung Cooling Fan Set for HLR5667WAX/XAA
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Black vertical line on p42w34p plasma
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Tv goes off, then comes on, and volume goes to max
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
