Question about Sony Playstation 3 (PS3) Console
My ps3 had been sitting in my truck for about 2 days in 75 to 80 weather it played wonderful before and everything worked.. now after it turns on normal ejects disks normal and everything works normal except that it would produce any audio or video on any tv and with rca or hdmi cable that I got with the ps3.. help plz
  • 490 Answers
Hold down the power button when it is on till it turns off
Posted on Jun 29, 2009
Tried almost everything, please help
It is because It is because fat partitions dont suupport manupulation of files bigger than 4 gb. Convert it to ntfs and it will work. And you might wonder that it worked for 15 min. ISo when you play a game lots of cache is generated and size of game is nearly doubled so this causes problem on a fat partition. And on
Jan 07, 2014 | Sony Playstation 3 (PS3) Console
Why does my playstation 3 keep turning off and the red light keeps flashing?
This can can be any one of numerous issues. The first step toward setting everything to rights is to discover what the light is trying to communicate, outside of the obvious fact that your system is not working. First, disconnect everything from the unit, power cable, HDMI, component cables, controller-charging cables or anything else you may have connected.
Allow the unit to sit and cool off for a few minutes before re-attaching all the component wires. It is a good idea to begin with just the connection to the television. You can also try a manual reset of the system if the above steps do not work, simply press and hold the power button for ten seconds.
If none of the above works, you are dealing with a serious PS3 flashing red light issue. This could be a faulty power supply, dead hard drive or malfunctioning CPU just to name a few. You will need to check all these components out and determine if they are still functioning correctly. Screwdrivers and a few other common household tools may be required.
How old is your playstation?
Also try this link if you playstation is outside of waranty
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
Lost connection when trying to play online
hard wire the ps3 to the router first to see if connection is lost.............if not it's interference between ps3 and router
Aug 01, 2009 | Sony PlayStation 2 (PS2) Console
Ps3 will not play any games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
My ps3 turns on but wont go to the menu screen its just blank
OK you need to check the video connection behind the PS3 then behind the TV. If you checked that and everything is OK, I would hold the power button on the PS3, when its off, for about 2-3 seconds or until you hear 2 beeps. Then a screen should pop up and you should be good. If you have any other questions, just let me know. Thank you and have a wonderful day. Don't forget to rate the overall satisfaction of this solution.
Jun 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is playing ps2 games but not ps3 games
Your blueray is broken,
you can try and do a system restore which will reset everything like the first day your turned it on just
go to -- system settings/system restore/format hardrive-- also be sure you backup your filessystem restore eg. your game saves.
If that doesn't work you'll have to call sony and send it in for repairs 1-800-345-SONY to receive repair/replacement they will send you a box to send your ps3 in. Its free if your still under warrenty but since your ps3 is playing ps2 games most likely your warrenty is gone. So it will cost you 150 bucks.
I hope the system repair works for you, it has for a few people.
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
PS3 signs off when playing games
I had same problem. Nothing worked so sent it back and sony replaced console in 2 days.
Feb 27, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
