Sewing Machines Logo
A
Anonymous Posted on Jul 12, 2014
How to remove top cover of lily 550
Thread stuck in one of tension disks? unable to pull it our
deborahcha
Level 2:
Novelist:
  • Husqvarna Expert 371 Answers
  • Posted on Oct 16, 2014
deborahcha
Husqvarna Expert
Level 2:
Novelist:
Answers
371
Questions
0
Helped
147578
Points
481
Make sure the presser foot is in the up position. This will open up the tension disks. It takes a lot of patience to remove imbedded thread. Use tweezers to grab the thread. Rock the handwheel backwards and forwards to help release the thread. If all that fails, have it cleaned by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the viking website - http://www.huqvarnaviking.com/us
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Mar 19, 2009
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
deborahcha
  • 371 Answers
  • Posted on Sep 24, 2009
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
deborahcha
  • 371 Answers
  • Posted on Feb 11, 2010
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Irene Tulloch
  • 498 Answers
  • Posted on Dec 20, 2010
SOURCE: When piecing a quilt top,
You need to give it a helping hand over the thick seams. There is a gadget called a jean-a-ma-jig which could help.
Or sew up to the seam, leave the needle in the thread, lift the pressure foot, then insert a thick piece of card from behind to make the foot level with the seam, lower the pressure foot then sew.
The idea is to make a level surface instead of a bump to sew over. Improvise any way you can.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Feb 09, 2012
SOURCE: Is the Lily 550 compatible with both 110 and 220 voltage or do I need an electrical converter?
check with the sewvacdoctor.com
Pfaff needle thread tensioner on a 1471 isn't adjusting properly. How do I gain access to the discs to determine the problem?
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top from the beginning.
Set the top tension to the midway point and try your machine again.
If there are still issues with the top tension and adjusting the tensioner isn't working, there may be gunk, lint or thread stuck in the tension disk. Remove the top thread. Set the top tension all the way to Loose. RAISE the presser foot. Dip a length of perl cotton in rubbing alcohol, squeeze out the excess, and then "gently" pull the perl cotton "DOWN" through the tension disk a couple of times. See if that helps.
Thread around wheel
If it were my machine I would pull the back cover for better access to the rotating shaft and remove the remaining thread. If the thread works its way into the shaft bearings you will have a real mess.
Don't ask me how but I have managed to get some thread around the hand wheel and it is stuck. It is the Lily 550 which I love. Is there anyway I can remove the wheel to get at the thread.
If your machine has a free motion knob there should be a small screw visible. This is the knob stop screw, undo this and the knob can be fully unscrewed and then the wheel can be slid off
How do I thread the Lily 540 for twin needle sewing?
You need to have the auxiliry spool pin threaded, a twin needle of course, and the threading is the same exept when you go through the tension. You have to make sure you have one thread on each side of the center tension disk. And that's it. Make sure you only sew straight, or small zig zags. Or else you can break a needle.
5helpful
Bobbin stuck on winder
Sounds like you need to remove some thread off the bobbin to get the pressure off. Sometimes if you wind too fast or you have a poor quality thread, the thread will stretch as it winds and causes to bobbin to compress onto the winder shaft.
Good Luck!
My Lily 540 always seems to be out of balance. Manual gives instructions, but they don't work. Taking it to the shop means the machine is out for a week and it costs me money. Can't I fix this mayself?
I'm assuming you mean thread tension., Check the upper tension area to make sure you don't have any loose threads or fluff in that area. When there is, the machine thinks the upper thread tension is tight when it's not. Good luck.
5helpful
2answers
Bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
1helpful
O cannot quite get my tension right.
Adjust the dial below upper tension unit (where you thread the top thread) to increase/decrease tension as needed. You might also want to check for loose threads or fluff in the tension area keeping the discs from closing correctly. Good luck.
4helpful
Husqvarna lily 540
bobbin wound too tight. remove thread first then pull off bobbin.
3helpful
Tension has thread caught in it.
Hope this helps. In the order I would recommend:
  1. "Floss" the tension disks - this is nothing more than running a heavy thread (12 weight or upholstery) through the thread path, grasping the thread at the spool and the end that is through the needle and "flossing" just like you would your teeth - slide the thread back and forth through the disks/thread path. This will often-times pull through whatever is stuck!
  2. If the thread is more deeply tangled than "flossing" will fix, you CAN remove the top of the machine to better see it. I would, however, recommend you take the machine to a Pfaff-trained tech if this is the case - things that can be damaged if you're not trained on the machine. However, if you're wanting to give it a try (the thread may be easily visible and easy to get to):
    • Remove the stitch lid - there are little metal clips at the base of the lid that you can push outwards to remove the lid - can't get the top off without removing lid.
    • In the well of the machine top are a few screws (2 if I'm remembering correctly). The screws are star-shaped as opposed to Phillips or Flat - special screwdriver is required. Just make sure you don't remove the screw that's holding the bobbin-winding mechanism on.
    • Once the screws are loosened, you'll have to maneuver the top out of it's position - this requires a little wiggling but is not impossible (just impossible to describe how to wiggle it!!)
    • Turn machine OFF and UNPLUG it. Too many electrical connection points you will be working around to take a chance!
    • VERY CAREFULLY... turn the handwheel towards you (never turn backwards) until you are able to view the entire race/thread path. If you can EASILY remove the stuck thread, go ahead and do it. If you have to do too much pulling and tugging, be VERY careful - if the thread is wrapped around the check spring, you may bend/break it.
Again - hope this helps!
Happy sewing,
Kim
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
