Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
A model number would have helped me diagnose your unit but because you say that you have white dots on the screen, and the unit is only 3 years old, I will go with what I believe your problem is. I am assuming that you do not have a CRT projection unit. I believe you have an lcd projection tv which is starting to have TFT panel failures. As they age they lose more and more pixels which show up as white dots. The only cure for this is a new optical engine. Cost could be on the order of $350 US. The replacement is not that difficult and can be done using my tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which will walk you through the process as well as link you to the best place to get the parts you need.
Thanks for using FixYa and for the excellent rating. Great ratings keep experts helping everyone solve their problems. Thank you.
Light Engine Call Encompass Parts Distr. 1-800-638-3328 or UED 1-800-648-6657 and you can CK them out online.Part# showing to be BP96-01468A thats if your Model number is HL-S5086W Make sure you have coerrect Model number.
The white dots/stars you are seeing is a failing DMD board. It is the board with the million little mirrors on it. The white dots are mirrors stuck in the on position always reflecting the white light from the lamp. The DMD board is a technician replaceable item and part number varies by model code. Please contact a local servicer to have them look at your TV so they can order the right part number for your DMD board. Please take a moment to rate my answer. Thanks....
it seems like you might have an issue with your dmd board. Go to the tv menu and if the dots also show there, the issue is with the dmd board, but if they don't, it's with the video board
Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
Sony wega blue dot or star pattern on screen http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655 Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
